ATK LM-7 5.7L Nitrous Build Up
This is a build we are doing for a good friends 2004 GTO with a T56, Monster Twin Disc Clutch, 3.46 gears. Shooting for the 450-500HP on Motor + a 200 shot.
LM-7 Block machined/bored to a 3.903
ATK Reground 3.622" Crank
Scat I Beams with ARP 8740 Bolts
Wiseco Flat Tops 10.5:1 Compression
Wiseco GFX Rings Gapped for Nitrous
#799 Heads Ported by our very own Matt Helms In. 301cfm / Ex. 203 @600
Stock Rockers with Trunion upgrade
Straub custom Hyd. Roller Cam .225/.231@ 50 .537/.517 110LS
Fast 102mm Intake/Throttle body/Fuel Rails
Powerbond 25% Underdriven SFI Balancer
The engine will be dyno'd with a carb setup at first and will report back with EFI and RWHP numbers when done. Should be a very nice Street/Strip Combo.
Just waiting on pushrods and she will be ready for the dyno.
Just got it off they dyno, this was with the old Edelbrock Performer RPM Intake and a 750 double pumper. We would have liked to used a nice single plane, but this was just for a reference. We will be getting it in the car and adding the Fast LSX 102mm Intake and Throttle body with a good tune and see what she does. We made another pull to 6500 and she held on making peak power at 6300 RPM on that pull at 470HP.
That TQ curve is insane and is going to get this GTO moving!
Any head will reach a lift that 100% fill rate of the cylinder at the given rpm range is achieved. You want to past this by about 10%. After that anymore is a waste.
"Bigger is Better" is the marketing theme this industry is based on...I'd rather say the "Combo is King".
Since torque is what we measure I told Brandon and the owner that this little engine is going to surprise some people.
There is a large market for this type of build. We get a lot of customers with LS1/LS6 engines looking to go to an LM7 based build to have a stronger foundation.There's a lot of people looking for that 450-500HP Range that dont want to pay the additional $ for an LQ4 based build since core costs have jumped and are very hard to get.
I actually love the combo. It shows what a stock ls1 shortblock can do with the same heads n cam setup on an actual engine dyno. Lots here also doing the 200 shot on a stock rotating assy. If I were to do another build it would probably be similar to this top end setup with a comparable size hit on the bottle. Thanks ATK for the info.
Thank you guys. We have an appointment for the 19th for the chassis dyno. He decided to order new Spintech exhaust and wants it on for the dyno.
We have a few other similar builds coming up that we will post the results on. A few LM7 383 versions with TSP ported heads, one like this with a cam that has more lift, few LS6 combos amongst other builds. We will be playing with cams as well getting a new line of LS engines together finally. Everything we do now is custom.
We had a bit of a delay. During the original chassis dyno session 2 injectors stuck on him. Had to order up some new injectors and wait to save up some $ for another tuning session....but we finally got it done last night. Ended up with Siemens Deka 42lb injectors.
Andy @ Prime Tuning here in DFW did the work on Keith @ Speedteks dyno jet, thanks to these guys!
She ended up making 386HP/380 TQ at the wheel, right at about a 15% loss. He is still breaking in the new clutch, but the TQ really puts it down on the street! With some seat time this weekend, hopefully the clutch will be broken in to really lay into her!
