Texas Speed's 2.5 Upgrade... 241/853 vs 243/799
Hey everyone, I have a question that I've sent to Texas Speed but also want some people's opinions as well. Let's begin with the main question:
How do PRC 2.5 upgraded LS1(241/853) heads stack up against PRC 2.5 upgraded LS6(243/799) heads?
The flow chart for the end product can be seen at this link, however read the wording above the chart... it specifically says LS6 cylinder heads. Meaning this chart represents your end product if you send them 243/799 heads. I can't find a flow chart for the end product you get if you send them 241/853 heads for porting.
https://www.texas-speed.com/p-1172-p...-castings.aspx
Now, for some information about myself. I have an SLP lid, stock MAF, stock TB, and ls6 intake. This is a street car that is currently daily driven and will be for a while, and will be seeing occasional drag strip after I get my house and a daily driver this summer. The car has a built 4l60e with a 3800 loose stall and 3.73s in the 10-bolt. The car is a 1998 so I currently have 806 heads. I have a cam whose specs I will attach to this post. My heads are my limiting factor right now and I want to change them. I have received a set of 853 heads for free from a friend. I am wondering if I get these ported with the 2.5 upgrade and put them on if I will get the most efficient setup while keeping the ls6 intake (I do not want to go FAST 92 or 102 at this time). OR, if I should buy 799 heads from my other friend for $400, send those to get 2.5 upgraded, and put them on.
I am waiting for a reply from Texas Speed on the flow #s for the 2.5 upgraded 853s I'd have if I sent them the heads I currently have sitting in my room and their opinion on what the right choice is for me, but was wondering if anyone here had any personal experience with doing this and any footsteps I should follow in or mistakes I should learn from. I COULD spend the extra $400 for the 799 heads, but would prefer not to, especially if the end product will be overkill for the rest of my setup.
The ported 799 heads will be a slight upgrade from the ported 853's. Is $400 worth it for the 799's, I think it's not a bad deal at all. If I were in your shoes, I'd do it if I could swing the extra $400. But don't think ported 799's is going to be a night & day difference from ported 853's. Honestly, you probably wouldn't even notice a difference on the "butt dyno".
I'm expecting a considerable difference from my 806 heads no matter which one I choose but between ported 853 and 243 20hp might actually be worth it... do it once do it right I guess. Thanks for the input guys, everyone else feel free to chime in too as I'm still deciding.
Moderator
Received 1,836 Likes
In general, I see the 243 as the best of the factory cathedral ports, and I just don't think you'll go wrong with them. And be honest with yourself - will you in a year ask yourself what if? If the answer is yes, then just get the 243 and know you left nothing on the table
Texas Speed Replied:
Wow, this makes this quite a bargain. Only 10-15cfm less? If he's right, the 862s are by far the cheapest and most efficient option.
"I personally would not mess with the 853 heads as they have a pretty large chamber and you will see a decent amount of gain out of the compression alone from the LS6 or the 5.3 heads even. The 2.5 LS1 style heads will flow about 10-15CFM less than the LS6 on average when they are both done similary. If you would like to get this going or if you have any other questions please let me know. I personally would look for a 706 or 862 which will have the smallest chamber and would work well with your combination."
Definitely best bang for buck I can find. Especially since it seems like you can't find a lot of ls6 heads anymore. They've moved on to LS3 and even LT1 stuff now. I'm going to request actual flow chart and see if they could get my compression to 11:1 on those 862s if they port them. I'm liking this guy's responses so far and TSP has come through for me before!
I'm running the 5.3's milled at 59cc and have around 11:1 compression.
Flow chart for PRC Stage 2.5 5.3 and LS6.
https://ls1tech.com/forums/generatio...2-5-heads.html
