Question about Howards ASA cam vs modern cam
I have a chance to buy a Howard's ASA cam, and was wondering how it performed with 1.8 rockers. My current cam has 223/230 duration, 113 lsa .610/.613 lift on xfi lobes, and I think it will be brutal on valve springs. I don't want to worry about high rpm shifts and if my valve springs will last long. They are Pac 1218,s. I know it has been posted on here before, but I was curious about any recent info.
Moderator
Received 1,836 Likes
Funny how your signature and warning in the post are oddly discordant with each other...
Iv noticed the horwards Hotcam, ASA cam and others say advanced lobe design for increased performance.. iv often wondered what this meant, always thought perhaps it meant, the lobe lift has a greater ramp rate than the original GMPP design and is one of the reason i haven't gotten one, i mean the price is awesome iv totally been wanting the ASA cam
I run the Howards ASA cam with SLP 1.85 rockers, with PAC 1211x springs with Brian Tooley hardened pushrods.
The cam lobes have an aggressive ramp rate to them.
I spin mine to 6800 and haven't had any issues.
I'm now spraying a 200 shot on it and it loves that as well.
Also so this aggressive ramp rate is like what, i read people saying XFI, EPS, LSR, XR and what not, would you happen to know what howards asa cam lobes are ?
Thanks and peace
Haha dude sweet man Oh hey can i ask ya, are you running SD or MAF and if SD is it SD enhanced, reason i ask is, your still able to monitor misfires right, if so well, did you have to modify your misfire count tables? as im running a hotcam and so for in two different engines, it causes idle and low rpm misfires.. and of course since the ASA cam is basically the same as the hotcam... thought id ask
Edit: ha nvm i see your maf, so yeah did ya have any misfire problems with this cam and have to mod your misfire count tables ?
In another thread I was also trying to convince someone to use dual springs on a 1.85 ratio low lobe lift application and then Mamo decided to take my sentence and run it directly into the innuendo gutter. Hilarious really that such a pro as himself would bust that out so I asked his permission for my sig. For no other reason than the humor really
Awwww man, do you have a video of your car.. i would totally like to hear how it sounds got youtube ?
Thanks and peace
Thanks and peace
If somebody has a Howard's ASA cam card I could figure it out.
Moderator
Ok so i have the Ls hotcam cam card but it doesn't have all that info the howards cam card does.. do you need all that info like intake open, TDC overlap, exhaust close, intake close, exhaust open to find out ramp rate or lobe intensity and if you will please what numbers are need to do the math or what would i call it, if i were to do a search to find out how its done ?
Thanks and peace
Thanks and peace
