Issues with TSP valve seals
I bought a cam kit from tsp and have been having issues with getting the seals to seal. Cars been burning oil and I had the whole thing professionally installed. Changed my oil today and par of the damn seal is on the magnetic drain plug with other **** on it too. Really upset after spending $1k on a cam kit. Any ideas how to get the seals to stop breaking and leaking? Thanks
Yeah I'm sure he did. He said he felt funny about the retainers but nothing quantifiable. They're titanium but should work fine in the kit huh?
LS1Tech Premium Sponsor
The typical cause for valve seals splitting or leaking are improper install. Either not seated properly or the installer seated them too far. The only time I have ever seen a spring retainer make contact is when the installer got lazy and reused a different spring seat or retainer that was already on the car instead of the ones we send in the kit or the valve seals weren't seated and popped up to let the retainer make contact.
Lonnie
Lonnie
__________________
NOW OFFERING TSP BY YANK CONVERTERS
COMP - FAST - PACESETTER - WISECO PISTONS - LUNATI - CALLIES - NEW TSP BRAND CRANK & RODS - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - ARH HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - PRECISION INDUSTRIES - YANK - CIRCLE D - AND MORE!
NEW NUMBER (512)863-0900
The typical cause for valve seals splitting or leaking are improper install. Either not seated properly or the installer seated them too far. The only time I have ever seen a spring retainer make contact is when the installer got lazy and reused a different spring seat or retainer that was already on the car instead of the ones we send in the kit. Or the vale seals weren't seated and popped up to let the retainer make contact.
Lonnie
Lonnie
It's not hard but is easy to screw up. My first time I trashed a few. See here for the correct tool..there are also plenty of other threads on the subject.
https://ls1tech.com/forums/generatio...eal-depth.html
The tool is really simple and I see why a lot of folks use a socket. I used both and the tool just feels right and has no compromises. Pay no attention to the 1-star reviews for that tool. It is obvious they didn't know they had to remove the small springs form the tops of the seals before installing("tool squished my springs").
I just got new ones, proper tool, proper procedure and no leaks. Luckily those seals are quite cheap.
