MLS or Graphite? Preferred head Gasket?
Which head gasket is preferred for use. Will be using 5.3's and car is an 02'. Which are the correct part #'s also. Did a search and got several different part #'s. Thanks.
John
John
I like the Graphite Dana gaskets because they are cheap and thin... but the MLS gaskets are a heck of alot easier to clean off the block if you ever pull your heads off again.
!LS1 11 Second Club
I had this same dilemma.
I bought both the MLS and the Graphite gaskets.
When I pulled my stock heads off, I saw that the stock gaskets were MLS, so I chose MLS. The graphite gaskets that Gomer mentions will work too.
I have the part #'s.... written down somewhere, I'll post up if I find them.
!LS1 11 Second Club
Originally Posted by AidanN20
if you order mls gaskets from dealer, 02 z06 mls gaskets were $40 for the pair, very cheap
Be advised that with MLS gasket you'll loose .1>.2 CR.
Originally Posted by SouthFL.02.SS
I don't see it that way for an '02. We didn't have that .1 or .2 CR to begin with if we had the MLS as stockers.
I now the MLS is thicker.
The mls tri-metal gaskets have been measured at .043 crushed on a couple of occasions. I haven't seen them over .045 and that could have been that someone re-used head bolts . I think the mls gaskets are thinner than the graphite ones. Be advised though if you use the tri-metal gaskets that they will not work with some ls1 applications. You need to make sure.
Originally Posted by MyLS1Hauls
The MLS gaskets cannot be used with older 98-00 heads if they have the mold release groove on the deck. If they are used, they will leak coolant.
From everything I've gathered either is fine as the 6.0 heads are pretty new castings and don't have teh casting notch in them. The MLS seems to be a little thicker and will lower the compression just a little.
