Comp "R"s and shims WTF
Old 06-21-2004, 07:36 PM
destroyerSS's Avatar
Default Comp "R"s and shims WTF
Ok i'm getting ready to install my new heads,LSX, H/S roller rockers, plus more and my ? is should i shim my H/S RR's for these comp r lifters or sell them and get a adjustable RR's. BTW my new heads have Comp 977 springs. Please help Thanks Shawn
Old 06-21-2004, 08:05 PM
felton316's Avatar
It depends if you have too much preload, then yes you will need shims. I'm running Comp R's and milled heads, and I did not need shims.
Old 06-21-2004, 10:59 PM
Squintz Palladoris's Avatar
I have seen this debated many times on here before. The guys who shim them are hit n miss but the guys with adjustables have no problems whatsoever. These lifters are designed to work with an adjustable rocker.
I am running comp R lifters with crane 1.7 adjustables. They were easy to adjust and since its a hydraulic there is no need to adjust them again.
I got mine from VINCI they call them "Accelerated lift" and say they are a 1.79 ratio. At full lift they are 1.7 Here is a link http://www.vincihighperformance.com/
Give them a call they are great to do bussiness with.
Brad
Old 06-22-2004, 09:56 AM
Nasty N8's Avatar
There is absolutly no need for adjustables you just need to get the preload correct for the Comp R`s. They are still hydrolic and require 1/4 to 3/4 turn preload.
Nate
Old 06-22-2004, 06:44 PM
Nate
Nate it sounds like you have done a few of these set up's! Where did you get shims from and how do you set such a slight preload with the shims. Any help is great.
Old 06-22-2004, 07:45 PM
Z06PSI's Avatar
Hey Nate or anybody else. I have a question. Are the Comp R's the only ones who need to be preloaded.. the reason I ask is that I found some other roller lifters and was wondering if they are going to need to be preloaded or just tightened to 19 ft lbs..????????
Old 06-23-2004, 03:23 PM
Z06PSI's Avatar
ttt Anybody
Old 06-23-2004, 07:32 PM
Unaffliated Racing's Avatar
Nate your information is incorrect. The R series lifter requires .002"-.004" of preload. These guidlines are here for a reason...use them. Comp also now offers pushrods for the LS-1's in .025" increments for these problems
7794-16 5/16" 7.325"
7795-16 5/16" 7.375"
7796-16 5/16" 7.425"
7797-16 5/16" 7.475"
