How Good or Bad are Stock "317" Heads?
Old 03-28-2017, 07:51 PM
Stampede4ever's Avatar
Default How Good or Bad are Stock "317" Heads?
I have came across a LQ4 with 317 heads, and was wondering should I just keep those or find a set of affordable 799 heads? I've read the the 317 flows close to the 799, but has a bigger CC. Or buy a set of use L92 Heads? Looking at building a mid street car/daily driver.
Thanks.
Old 03-28-2017, 08:47 PM
Super Hulk Smash
JakeFusion's Avatar
317 are the same as the 243/799 head but with a larger combustion chamber as you have noted.
So it flows fine. But for a street car, I'd want to bump the compression. If you are running boost... the 317 untouched would be a good head. L92/LS3 heads stock would be an upgrade for an FI motor. But NA, I'd just keep the 317s and get them ported and possibly welded up. Advanced Induction does combustion chamber welding. So you could get it at 60cc or something without losing piston to valve clearance.
The following users liked this post:
Homer_Simpson (12-01-2021)
Old 03-30-2017, 07:01 AM
z-maro's Avatar
Like Jake said the chambers can be welded up to bump compression. I am using a set of 317's on my build that Advanced Induction ran their 232cc CNC program on, and welded up the chambers to 62cc. They actually may flow slightly more than a 243/799 head with the same CNC program that were milled to 62cc because I believe milling heads negatively affects the flow.
Old 08-03-2018, 08:46 PM
Hotrodhoop's Avatar
Default Good Choice
i have an lq4 into a 408 with 862 ported heads, mild cam, stock truck intake, stock flex fuel injectors, stock exhaust minus short tube headers, 2500 stall with 4.10 gears and it pulls well to 5,500. Makes 448 rwhp 472 ftlbs. Installing some 799 heads and will see what happens?
Old 08-06-2018, 12:07 PM
Ls7colorado's Avatar
448rwhp with stock truck intake and stock exhaust manifolds??? Wow,
what does minus short tube headers mean?
Old 08-06-2018, 12:47 PM
Hotrodhoop's Avatar
all stock exhaust accept manifolds have been changed to short tube headers.
Old 08-06-2018, 01:57 PM
Ahhhhh gotcha, nice numbers, and great torque! to peak at 5500 though im sure its getting choked
Old 08-06-2018, 02:47 PM
omc8's Avatar
Having Ai weld up the chambers is a great option , I like to know if they will do the chamber work A la carte or have to be done with other services minimum rebuild or cnc work .
Old 08-06-2018, 05:20 PM
Utinator's Avatar
I just bought a set of 317 heads for my stock LS1. I was going to have the heads milled and ported, but I don't know what to tell the guy doing the work. He was asking about chamber size (what cc). I have no idea. I know the 317 are lower compression, so I want to increase that. I thought milling the heads would increase the compression, so why would you weld them? Does anyone know what the compression ratio is on stock LS1s?
Old 08-06-2018, 05:22 PM
00pooterSS's Avatar
To increase compression you make the chamber smaller, you do that through milling or welding in material to take up space. Welding in material allows for more valve drop (more distance between the piston and valve).
To know how much to mill you need to know what compression ratio you want.
Old 08-06-2018, 06:32 PM
Utinator's Avatar
I was hoping someone could tell me what compression ratio I want. I just read several threads about heads, cams, valve springs, and intake manifold CFM. Anyway, I found a thread that said the stock LS1 has 66.67 cc for 10.1 compression. I'm guessing I need to stay close to that in order to keep the car running well. I'm planning a cam swap at the same time, so I'll probably just start a new thread. I really just need to know how to make these heads work with everything else I already have.
I know the heads have to be milled due to a rough spot caused when the head gasket blew. I'm guessing about .010" would be enough to "clean" the mating surface. of the head. I'm not sure how much that would change the compression.
Bigbirdtrucker (01-18-2020)
Old 08-06-2018, 06:37 PM
Received 3,022 Likes on 2,353 Posts
What kind of gas are you going to use? 91, 93, E85?
Old 08-06-2018, 06:39 PM
Utinator's Avatar
I'm starting a new thread. I don't want to de-rail this one.
Old 08-06-2018, 06:41 PM
Cool! Good idea!
Old 08-06-2018, 10:18 PM
wannafbody's Avatar
Maybe you could sell/trade 317 heads to someone who's going forced induction and get a set of 243s.
Old 08-06-2018, 11:02 PM
ss.slp.ls1's Avatar
If you have the budget for LS3/L92 heads and intake I would go that route. It really depends on your budget and horsepower goals.
Old 08-08-2018, 12:09 AM
Well, I bought a set of 799 heads, and those are the ones will be using for now with an ls1 intake on a LQ4, but I do have good set of 317s. What is the average price to have them welded up, and ported? And I think I have a set of 823s, I have to look again tomorrow. Looking at the next motor, would really like to get a 6.2 block, this is coming from an old 5.0L guy, and I really liked the smaller cubic motors, but with the ls, I want big as I can, or just add boost.
Stampede.
Old 08-13-2018, 09:15 PM
rednari2's Avatar
Here's a suggestion. You could use thinner HGs, if the pistons are flush or slightly out of the deck. This will also give you two things: 1) The quench distance will tighten thereby increasing the squish; and 2) the larger chamber has more A/F volume. PVC should not be a problem because of the larger chamber and the increased squish makes more power and acts like octane to resist detonation. Besides you already own the heads so port them and cut the EXH throats.
Old 08-13-2018, 09:54 PM
Tuskyz28's Avatar
A really simple powerful combo but still affordable.
Basic 6.0 shortblock
TFS 228/232 cam
LS3 intake
LS3 heads
long tune headers
Car craft just built this exact build this month and made 515 horses at the crank.
The following 2 users liked this post by Tuskyz28:
Bigbirdtrucker (01-18-2020), Nodaysoff (03-04-2020)
Old 08-14-2018, 05:03 PM
fakky's Avatar
Never heard of this.
What kind of costs ?
Quick Reply: How Good or Bad are Stock "317" Heads?
