Flycutting Pistons?
Originally Posted by 01midnightss
Does anyone know whats the max you can flycut your stock pistons while staying on the safe side?
Originally Posted by '01 WS6 TA
My motor personally has 60 thousandths taken off and I'm currently spraying a 175 shot through the motor with no problems at all. I also know someone with 90 thousandths off spraying around a 200 so I say it's all up to you.......do you plan on spraying the car?
I can shift faster than you.
I have cut over .125" reliefs in the stock pistons without any problems. I wouldn't recommend going much more than this though, even though the stock piston does have quite a bit of material in the area where you are actually cutting the reliefs.
.060"-.080" is a pretty safe amount.
Jason
Jason
