Current valve spring of choice?
Whats the current valve spring of choice?
I'm running GTP Stage 2X heads, and a cam that is a tad over .600 lift.
It's time to replace my cam with a better & bigger one.. springs need to go as well.
TIA
TIA
VHP dual springs. i run them in my car. sponsor on right. link to springs here. http://www.vincihighperformance.com/superwebdeals.HTML
2 for Patriot..
1 for VHP..
1 for Isky..
Like I said.. I'm over 600.. do all of the above handle that ammount of lift? Any of them require anything special over what I already have?
I've already got retainers, etc.. I hope that I can just replace the springs, and not have to spend extra on stuff I already own.. unless I HAVE to.
1 for VHP..
1 for Isky..
Originally Posted by calongo_SS
I believe the patriots will require special retainers because they come with special (super 7) locks. I don't have them so i don't know how your retainers and locks will fit. Someone else chime in now to make up for my ignorance...
I have the Crane dual valve springs in stock, along with tit. retainers, and spring seats. They are good to about .650 lift and would work great for your aplication. Let me know if you need some!!
Suspended Sponsor Account
we are starting to use the Patriot duals, they are very nice and are of high quailty. we have some sets in stock ready to be shipped.
the crane and comp duals are also nice
all are reliable
all are reliable
Brad
Another vote for the Patriot golds, the 921s are great too but as some said are a bit pricey. Just depends on what your looking to spend, either one will do fine.
brian
brian
Which will work in a LT4 396 stroker? The cam is a custom ground Comp.
Int. Exh.
lift .540 .562
duration at. .576 .600
.242 .248
lobe sep. 112
Comp. hydrolic roller lifters and cam
pro mag rockers 1.5 and 1.6
202 valves
I need the springs to be good up to 6800 rpm w/o going to solid roller lifters.
Thanks,
Andy
Int. Exh.
lift .540 .562
.242 .248
lobe sep. 112
202 valves
Thanks,
Andy
Collections Hold
springs
We use the Ferrea dual sport compact spring, never had a failure. 175 lbs on the seat, 450 open. The comp 918 springs are one of the best out there as far as stability and control. Seen a lot of testing on the spintron.
