I Have a Problem ! Please Help !
Old 08-12-2004, 12:01 PM
Nytmare's Avatar
Default I Have a Problem ! Please Help !
All of a sudden, my oil pressure has sky rocketed to over 100 1bs . What can be the cause of this ? I checked the oil and it seemed fine . I'm not driving it now, but do you recommend I drive it to see if it will smooth itself out ? I need help fast !
Old 08-12-2004, 12:05 PM
technical's Avatar
When was the last time you changed your oil filter?
Old 08-12-2004, 12:14 PM
Nytmare's Avatar
About 3 1/2 weeks ago .
Old 08-12-2004, 12:15 PM
Nytmare's Avatar
What do you guys think ?
Old 08-12-2004, 12:18 PM
9T9BlueTA's Avatar
I would change the filter and see if it returns to normal.
Old 08-12-2004, 12:19 PM
technical's Avatar
Bad sender or wiring. Unless you have a very serious blockage, 100psi is a bit out of reach of the stock pump.
Old 08-12-2004, 12:20 PM
Nytmare's Avatar
Can I drive it too the oil change place ?
Old 08-12-2004, 12:24 PM
Nytmare's Avatar
Changed the sender once before, but It was because of LOW oil pressure. I guess its an either or deal huh ?
Old 08-12-2004, 12:33 PM
technical's Avatar
I've seen senders send erratic signals as well as low and high signals. If there is a short or the sender closed it would send a really high signal.
If you turn the key to on ( not start), does the oil pressure gauge read 0 or 100?
Nytmare's Avatar
You guys still there ?
Old 08-12-2004, 12:39 PM
Nytmare's Avatar
Still high, about 80 or so then climbs when i start .
SeeYaSucker's Avatar
Its Most Likely the Sender or wiring, I doubt the stock pump will build 100, does it flucuate or stay pegged?
Old 08-12-2004, 12:44 PM
Nytmare's Avatar
Just rises when the car is idling.. can i drive the car anywhere now ( to the oil change place ?) or do I tow it ?
Old 08-12-2004, 12:50 PM
Nytmare's Avatar
Goes as high as 110 when idling .
Old 08-12-2004, 12:58 PM
technical's Avatar
So you're saying that the gauge reads 80psi before you start the car, correct? Then it's definately a sender/wiring problem and you're oil pressure might be normal and safe to drive.
Old 08-12-2004, 01:02 PM
Nytmare's Avatar
yes.. Ok
Old 08-12-2004, 01:03 PM
Nytmare's Avatar
Thanks !
