Main cap studs or just GM bolts.
Old 09-02-2004, 10:55 PM
goober35's Avatar
Default Main cap studs or just GM bolts.
Should i just break down and put ARP studs in or will the GM bolts be good enuff. 50 pill on a turbo motor 6.0 30 over.
Old 09-03-2004, 01:01 AM
taqwache's Avatar
GM bolts should be fine. thats what i use. but if you want to put ARPs in it, you will need to check your line bore. with the higher clamping load, it could distort it and you will have to get it line bored to correct it.
Old 09-03-2004, 01:17 AM
goober35's Avatar
Thanks man. I should have the motor together in a mouth or so just have to get this stuff sorted out before i can start.
Old 09-03-2004, 02:03 AM
jrp
SN95 Director
jrp's Avatar
ARP main studs all the way.
Old 09-03-2004, 02:10 AM
goober35's Avatar
OK JRP can u front me the other half of the cash.
Old 09-03-2004, 02:29 AM
jrp
SN95 Director
jrp's Avatar
with as much money as you already invested in your setup whats an extra 200 bucks.
Old 09-04-2004, 08:11 AM
Uthinkso's Avatar
ARP for sure
Old 09-04-2004, 12:36 PM
Hawkcmc's Avatar
The recommendation is to upgrade them but most just use the stock ones. If your in there and your worried about it and have the extra cash then just go for it.
CMC
