Replacing TR224/GTP S2 set up with smaller cam, recomendations?
The car is a 6 speed, 3.42 C5 vet. GTP stage 2 heads with 1 3/4" primaries and !CAT!. My set up breaths well. Without replacing gears, I want more low end TQ. My current set up takes until 4200 rpms to get to 300 ft-lbs of TQ.
I want something that is more fun from stop light to stop light, that you can take to the track and run 12.0s on steet tires . I want a cam that is somewhere between a 405 Z-06 cam and the tr224. I also want to limit rpms to 6300 to 6500 rpms. I have 987 duals and a speed inc built 346 motor. I dont want lift above .570/XE
Cams of interest:
220/220 114XE
221/221 114XE
222/222 115-116XE
400 HP and 390 TQ are what I am shooting for. What do you all think about my cams of choice, any recomendations?
TIA
Chubby
Cams of interest:
220/220 114XE
221/221 114XE
222/222 115-116XE
TIA
Chubby
The TR224/112 that you curently have has more trq down low than any of the cams you mentionned.
You could check the Vincy cams (Vinci High Performance), I believe there is a thread about the 047 going on right now.
or there is always the old faithfull from Comp Cams 216/220, .525/.535 114 lsa
Originally Posted by Chubby
My current set up takes until 4200 rpms to get to 300 ft-lbs of TQ. ...
TIA
Chubby
TIA
Chubby
The more low end tq you have, the easier it will be to spin your tires in first gear. If you're spinning, you're not winning...
Originally Posted by Ragtop 99
There is something wrong if you have almost 400 RWHP now but only hit 300 ft-lbs at 4200. That should be close to peak tq. Are your numbers right or is your sig out of date?
my wrong, it makes 375 ft-lbs at 4000 rpms.
I like the TR220-114. My torque curve is pancake flat from 3200 rpm to 5500 rpm it's stuck between 360 - 369 rwtq. I have stock heads. Add some TEA 1.5's and I think you would be good to go.
The TR224 cams typically make better mid range (3500+ rpm) torque than the TR220's. You might also look at your current head selection. I don't know much about the GTP S2 heads, but maybe a smaller port and increasing your low rpm velocity would help get some more low end torque. The 220 cams will definately be better with your 3:42 gears.
Another great street cam is the LPE GT2-3. Doing it again, I would put in the LPE GT2-3 cam.
Chubby,
Any news on which way you went. After looking at the GTP S2 heads, I just bought a set. I called GTP and talked with them about there S1 and S2 heads. Holy cow! Those are some sweet heads. Velocity is the name of the game, GTP certainly understands that.
Another way to get more torque is to raise your compression.
Good luck.
Good luck.
LS1 Tech Administrator
You could advance your current cam 4 degrees. This would shift the peak power and torque down about 200-300 rpm, but you would also make less peak power. If it were me, I'd consider a smaller cam with a narrower LSA. Something like 218/226, 110LSA +0. This would be very torquey down low and still make good power to 6000 rpm. Idle would be about the same or slightly better than the TR224/224 112 cam.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2018 Cadillac Escalade 6.2L A10 Pat G tuned.
LS1,LS2,LS3,LS7,LT1 Custom Camshaft Specialist For custom camshaft help press here.
Custom LSX tuning in person or via email press here.
Damn I was gonna say something was all fuc*** up if your Heads @ TR224 was only making 300rwtq @ 4200rpms. I am making 300rwtq at 2K rpms with my setup. As mentioned before going to a smaller cam will not make more torque your only gonna gain it by going with more compression, smaller head port volume = high velocity = more torque or a larger cam.
If everything is ok with the engine, Id get some gears. 4.10's would really wake it up.
Something doesnt sound right. The cam I got is supposed to be weak for lowend power yet it still has no problem hazing the tires in 1st gear from 2k and up. It isnt even tuned either and has mac headers which suck for lowend power. Granted its on regular radials but it doesnt have the front sway bar and 140lbs has been removed off the front of the car so it gets some traction.
I dunno something doesnt sound right.
Futral cam !
