Need Suggestions - around 7k to spend
I have a '98 C5 that is my daily driver with 108k miles. It is bascially stock with a older Halltech T-1 air bridge / filter and corsa cat backs. I want to add some go fast parts and plan on getting the work done by Mike Norris. Mike and I have been discussing a few options for my high milage motor but wanted to also get a few other suggestions before I finalize my plan.
If you had 7kish to spend on some mods what would you do? Keep in mind I will be having this work done by a tuner so I can't spend 7k in just parts. Another consideration may be to save up more money and rebuilt the entire motor but I hate to wait that long. I would love FI but without rebuilding the entire motor that is out of the question.
I would need to factor in new clutch into my price also. I want a street friendly car that does well in traffic but has a nice loop to it.
Check out Texas Speed's website and give them a call, I'm sure they can help you out getting your C5 setup right. www.texas-speed.com
With 7K to spend I would do a 408 iron block with S2 heads and mild cam
If you are weight conscious then a 383 stroker with alum block.
Set of headers with ORY and you are good to go
About how much does it cost to forge the bottom end for a FI set up?
