advantages of a 348CI motor?
Old 10-07-2004, 03:34 PM
freakynipples69's Avatar
Default advantages of a 348CI motor?
I know getting a 348CI motor, all forged out and stuff makes is A LOT stronger for higher horsepower applications, but does getting an actual 348CI motor add an HP? Like if i were to buy one, would it add any HP or just make my engine stronger? Sorry for the noob question but gotta learn some how
Old 10-07-2004, 03:44 PM
nitrorocket's Avatar
If it has stock top end, it will make no more power then a stock engine. A 348 with a forged lower end is usually for a nitrous, supercharged, or very high rpm application. Much stronger, but not necessary for stock type N/A setups. 1 more cube will make no noticable horespower over a 347" motor. Is this what your are asking?
Old 10-07-2004, 03:53 PM
Blue Hawk's Avatar
Since you have almost the same displacement than stock, it will make make the same HP and TQ than a regular 346 (assuming same mods, cam, heads, etc...).
With a forged 348, what you have is the ability to go much more agressive on mods (ex: a 200 shot of NOS). Basically, you just built a stronger engine that you can push harder. A better platform for radical mods.
Since you want a forged bottom end, why not go with a 382 or a 395? That alone will deliver more TQ and HP all across the curve, plus the ability to support a more agressive cam and a bit more CR (the benefits of the added cubes).
Old 10-07-2004, 04:10 PM
I wasnt actually gonna get one, i was just wondering what other advantages there was to getting one. Thanks a lot though!
Old 10-08-2004, 12:03 PM
AllThrottleNoBottle's Avatar
If you plan on going with forged internals, is there any reason not to go with a 383 stroker over just a forged 346?
Old 10-08-2004, 01:00 PM
PREDATOR-Z's Avatar
The financial factor
Old 10-08-2004, 01:11 PM
Blue Hawk's Avatar
No need for clearencing the block. You can rev a tad higher due to the shorter stroke (assuming the valvetrain can follow).
Old 10-08-2004, 02:05 PM
Well, besides the extra money , is there any downside to going with the 383?
Old 10-08-2004, 02:12 PM
PREDATOR-Z's Avatar
Not that I've ever experienced in the last 20 years.
Big cubes is where it is at for the track, otherwise FI, N20
Old 10-08-2004, 02:51 PM
Dumb Ass Vette Moderator
ls1290's Avatar
Lost traction
Old 10-08-2004, 07:43 PM
Ha, alright I got my answer, thanks guys.
Old 10-08-2004, 08:18 PM
BMW ///M Nerd
BAD ASS TA WS6's Avatar
Some consider it a waste of money. It being the middle man and all. It makes sense to me, build what you got, or build the biggest you can.
The prices on the bigger cube motors 400+ is really coming down so that is a factor as well. In a nutshell, that's why you don't see quite as many 382 or 395s kicking around.
Old 10-09-2004, 08:11 AM
PREDATOR-Z's Avatar
Well, bigger than 400 usually means Iron Block, so there is the weight factor. Personally, I would rather have a 382/383 than a 402/408, however as stated above the bigger the better then 427/434/455 would be my choice of heavy metal.
Old 10-09-2004, 10:08 AM
So is 383 as big as you can go without switching to an iron block? Does stroking a motor weaken anything?
Old 10-09-2004, 11:49 AM
Moderator
John B's Avatar
You can expect to see a slight decrease in overall power and especially torque with a 348 forged motor when compared to an identical 346 stock motor.
Old 10-09-2004, 12:56 PM
GMCtrk's Avatar
there has been aluminum ls1's up to 455 cubes
Old 10-09-2004, 04:30 PM
Mooobunnny's Avatar
I would LOVE to know why you say that?
In general lighter parts, and a better balanced and blueprinted motor equals mroe power. Maybe I am missing something here though...lol.
Old 10-09-2004, 04:37 PM
z98
z98's Avatar
You will see a few hp maybe. Nothing earth shattering.
Old 10-09-2004, 10:14 PM
Chubby's Avatar
my forged shortblock has been a hoot. Dont mess with the bottom end unless you have S2 or better heads, or want to run forced induction, or funny gas. If you go 383, good luck hooking up without slicks, my car is looses traction easily enough with good street tires and 3.42s, which are hopefully going to be swapped out for 3.90s by the crew at speed inc. one of these days.
Old 10-10-2004, 07:04 AM
2MuchRiceMakesMeSick's Avatar
Depends alot on the builder. Also things such as high compression / low compression will be the determining factors in how much the motor puts out.
