LS6 ported oil pump
Old 10-08-2004, 10:05 PM
ls6jimmy's Avatar
Default LS6 ported oil pump
What is would it if I put a new LS1 oil pump in over an LS6 ported oil pump the reason I'm asking is b/c I know someone that works for chevy dealership and I can get one cheap? Pro's and/or Con's
Thanks
Old 10-08-2004, 10:57 PM
cyphur's Avatar
wtf? grammer/spell check please....whats the question...would it do you any good to put in a new ls1 oil pump to replace an OLD ls6 ported pump? or what? need some help...no offense but that was one fucked up sentance there man....
Old 10-08-2004, 10:58 PM
LSUxBlake's Avatar
Yea I have no idea what you just asked.
Old 10-09-2004, 05:56 AM
ls6jimmy's Avatar
Sorry, I'm asking is there an advantage to having a LS6 ported oil pump over a LS1 oil pump. B/c I can get a new LS1 oil pump for cheap if there is no big difference.
Thanks
Old 10-09-2004, 10:39 AM
tomaSS's Avatar
Are you replacing your oil pump now or are you building a motor? You have not stated why you are looking at an oil pump. Typically, people put in the ported LS6 oil pump in their car to replace the suspect LS1 oil pump when they do a cam swap. The LS1 oil pumps have been known to fail but if you do a search then you will probably find the answers to your questions. Good luck.
Old 10-09-2004, 12:35 PM
cyphur's Avatar
Bigger cams = more demand on the motor. LS6 ported oil pumps seem to fare better with the bigger cams then ls1 pumps. its just another 'peace of mind' things, like a double roller timing chain or something like that. many people upgrade them during cam swaps. i have a ported ls6 pump sittin on my floor waitin on my cam swap.
Old 10-09-2004, 03:48 PM
ls6jimmy's Avatar
I'm building a ls1 for my jimmy the cam is 224/228 567/571 114.
Thanks
Old 10-09-2004, 04:10 PM
Phil'sC5vette's Avatar
i just ordered a ported LS6 oil pump from TSP.
what kind of PSI over stock are you guys getting
Old 10-10-2004, 07:33 AM
2MuchRiceMakesMeSick's Avatar
Thanks
Please do not get drunk and create posts on LS1Tech
Old 10-10-2004, 03:12 PM
LSUxBlake's Avatar
I idle at around 45 when hot and hit roughly 60 at WOT. I'm not 100% sure those are correct, just what I remember.
