Futral motorsports cam?
Old 10-16-2004, 09:37 AM
99ss00ws6's Avatar
Default Futral motorsports cam?
Does the f2 and f4 cams have xer lobes?
Old 10-16-2004, 09:43 AM
Candy's Avatar
No the F2 and F4 are not xer lobes. XER lobes are Comp Cam, we also carry their products as well.
Thanks
Old 10-16-2004, 09:53 AM
Scalpel's Avatar
Futral uses a different cam supplier/grinder. Cam Motion cams, I believe.
Old 10-16-2004, 10:24 AM
99ss00ws6's Avatar
How would the 2 cams I listed compare to the TR 224? Thanks
Old 10-16-2004, 10:53 AM
cyphur's Avatar
Cam Motion. Softer lobes then XE-R.
https://ls1tech.com/forums/showpost....71&postcount=8
thats a description of most of their cams.
the f2 will kick in earlier in the rpm range. f4 will kick in ever so slightly later. pull a little harder. both cams pull pretty far into the rpm range. pretty decent cams for a daily driver, good drivability. will run fine on 918's.
Old 10-16-2004, 02:22 PM
MSGHUFF's Avatar
I never can find anything on FUTRAL MOTORSPORTS cams where do you guys get this info/specs from? There website has always said "coming soon" for me?
Old 10-16-2004, 02:38 PM
Candy's Avatar
Yep sorry about that... we were getting our online ordering and info up in the new catalogs and it has taken a little longer than expected. We have most of it complete and have put in the request to have it routed to the new site, should be up sometime this weekend as long as everything goes as expected. I will post a link to it asap.
Thanks
Old 10-16-2004, 06:27 PM
jrp
SN95 Director
jrp's Avatar
http://ourworld.cs.com/jrpws6/cam+chart.jpg
Old 10-16-2004, 06:44 PM
MSGHUFF's Avatar
Thanks jrp
Old 10-16-2004, 06:55 PM
oOoLy's Avatar
What is the difference between the Cam Motion and the XE-R.
Old 10-16-2004, 06:57 PM
cyphur's Avatar
Cam Motion are softer lobes, less stress on the springs. Maybe JRP or J-Rod can pop in and give you more details.
Old 10-16-2004, 06:58 PM
cyphur's Avatar
And to answer your question, I spend entirely too much time on this site. I have no life. I also use the search button
Old 10-16-2004, 10:38 PM
cliffkh's Avatar
Thanks
Hello - can I run an FM5-114 on LS1 heads mille .030" and with comp 918 springs? Or is it too much lift? thanks!! Cliff
Old 10-16-2004, 11:18 PM
Josh's Avatar
I was under the impression that Cam Motion lobes were more aggressive than XE-R lobes.
Josh
Old 10-17-2004, 07:29 PM
Futral's Avatar
Cliff, You can run that cam without any problems. Total lift isn't the issue with P\V clearence.
Old 10-17-2004, 07:49 PM
Futral's Avatar
Josh
Yes,the hyd lobes we use are softer than the Comp XE-R series. They are closer to the LS1 high RPM series. In reflect of one person's belief\concern that some of our lobes are dup's of Ultradyne lobes, they are not. The lobes we use will RPM up to or past 7K without beating the valvetrain components.
Mike H''s car has been running the past 2 years with a 226\226 cam and 918 springs without any problems. Improper valvespring selection\setup(open\closed pressure and valve lift\ coil bind) is the biggest cause of valvespring failure and valvetrain issues.
Quick Reply: Futral motorsports cam?
