which cam would be the best for my heads??
.1000 68.8 59.5
.2000 146.8 124.1
.3000 205.5 184.1
.4000 251.9 227.7
.5000 292.5 252.3
.5500 307.9 263.4
.6000 316.9 268.2
trying to match a cam for my heads. or should i keep the FM11???
.2000 146.8 124.1
.3000 205.5 184.1
.4000 251.9 227.7
.5000 292.5 252.3
.5500 307.9 263.4
.6000 316.9 268.2
I would keep the cam you have now unless money is less of a concern than performance. May gain 10 or hp over that cam but that may be all but if I was to start from scratch it would be a Comp 54-446-11, 232/234-.595/.598-112lsa.
LS1 Tech Administrator
If it were me, I'd try the new combo with the F11. If you're still not at the rwhp level you'd like, then put in a serious bump stick. You will have fly-cut the pistons so the sky's the limit. A cam in the neighbor hood of 240/248 615/590 112LSA might work well, but you'd be giving up some street manners. With your higher compression, you'd probably still have decent streetability though.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2018 Cadillac Escalade 6.2L A10 Pat G tuned.
LS1,LS2,LS3,LS7,LT1 Custom Camshaft Specialist For custom camshaft help press here.
Custom LSX tuning in person or via email press here.
If it was me, I'd stick that F11 back in there and see what it does with the changes to the heads... THEN if I still wasn't happy, I'd look into something a little larger. I've changed the cam in my car a couple of times and I'm convinced that there is no "magic cam"... I would have found it by now
While I agree to some extent, there is something else to consider. You would only have to buy the cam, not the spring kit or anything, so it is only going to be like $400. You have spent A LOT of money on those heads (I am assuming), so I wouldn't put a cam in there if there is another one that will work better. Get one to match your heads and call it good. It's easier to change now anyway. Gomer, you have to remember that most people can't change cams like you can At least call Futral and see if another cam would gain you anything. Since you know all the flow numbers and everything, they can probably come up with something that will work really well. JMO
For $399.99 Futural will design a cam based on your heads and:
Head flow data (full range not just max)
Rocker Arm Info (ratio as well as type - i.e. stock)
Spring Info (seat pressure, open pressure, coil bind, etc)
Engine Displacement (bore and stroke)
Rod Length
Compression Ratio
Transmission (gear ratios if available)
Differential Ratio
Rear Tire Diameter
Maximum Intended RPM
Weight of car
Usage (i.e. all out race or street)
Same price as an off the shelf cam, why WOULDN'T you do it?
Rod Length
Compression Ratio
Differential Ratio
Rear Tire Diameter
Weight of car
SN95 Director
Rod Length
Compression Ratio
Differential Ratio
Rear Tire Diameter
Weight of car
Rod Length
Compression Ratio
Differential Ratio
Rear Tire Diameter
Weight of car
