1 More Cam Advance question from me....
If you have advance ground into a cam, will it increase the LSA of the cam?
Example: You have a cam with a 116lsa and you add 2 degrees of advance, will the LSA become a 118lsa cam?
Doesn't adding advance spread the lobes just that many more degrees apart?
Thanks Guys....
Bill
Thanks Guys....
Bill
Originally Posted by jrp
the overlap doesnt change.
jrp - i do like this part of your cam guide
people get so caught up in the numbers that they forget to look at the entire curve. typical can't see the forest for the trees.
1) For example if you installed S2 heads and a tsp231 cam and only put down 390rwhp tuned don’t fret if you started with a base of 290rwhp.
Originally Posted by Richiec77
You mean they can't see the forest when they are in front of the tree.
Man I love your sig. lol
If you are in front of the tree but can't see the forest it mean you can't think geometrically. You are to focused on a single point (peak #) and can't take in the whole picture. Don't you hate it when you grow up and your Dad is sooo right.
SN95 Director
nope. meant it that way. there are other things in a forest than just trees. just like dyno sheets. there are more things to look at other than just the peak numbers.
* numbers removed to illustrate a point
and back to our scheduled cam discussion
