Do you 'clean' a new cam before install?
Old 12-15-2004, 11:21 AM
Billiumss's Avatar
Question Do you 'clean' a new cam before install?
I haven't seen a thread like this before so I thought I would ask.
When you install a brand new cam, do you guys wipe it down with anything (mineral spirts) or do you just oil it up and throw it in right out of the box?
Bill
Old 12-15-2004, 11:25 AM
Krab's Avatar
When I installed my cam, I wiped it off a little, mainly through the center though because I was afraid it had some crap in there. The outside was pretty clean now that I think about it. Then I just oiled her up and slide it in.
Old 12-15-2004, 11:26 AM
LS1TECH Sponsor
mikey's Avatar
Always. Clean it with thinner and then oil it with a 40W oil before installation.
GuitsBoy's Avatar
You can use non chlorinated brake cleaner, or wd40, or just about anything to clean it and get rid of and metal shavings. Just make sure to dump a good quart of oil over it to coat it well.
Old 12-15-2004, 11:27 AM
LS69TA's Avatar
Don't ever put anything in your motor without cleaning it first. You never know what's on it.
Old 12-15-2004, 11:41 AM
STREET SHARK's Avatar
OMG i forgot too!
Old 12-15-2004, 11:44 AM
Zach@Texas-Speed's Avatar
Originally Posted by STREET SHARK
OMG i forgot too!
Say "bye, bye" to your cam bearings
Old 12-15-2004, 11:45 AM
luv2spd's Avatar
I ran some oil through the hollow core and then lubed it with some lucas oil. The lucas oil was really thick and really stuck to the cam.
Old 12-15-2004, 12:20 PM
1fastWS6's Avatar
I always use brake cleaner on mine, wipe dry with paper towels, then oil with the same oil I'm running in the motor (Mobile 1).
I'd be careful using any oil additives as a break-in lube. Some oil additives are terrible lubricants by themselves (STP for example). Just use regular engine oil, thicker the better so it stays on the cam longer until you start it for the first time.
Old 12-15-2004, 02:28 PM
Raise's Avatar
brake cleaner, hose off, dry with air hose, rub it down with cam lube
Old 12-15-2004, 04:23 PM
Bill Bowling's Avatar
Talking
What is cam lube? Where can you get it?
Bill
Old 12-15-2004, 05:20 PM
GeorgeC's Avatar
It's a very good idea to clean any new part before installing it. Brake cleaner works fine, I have a small parts washer I use personally.
There's absolutely no need to use any kind of traditional moly based cam lube with a roller cam. An ample amount of motor oil is all you need.
Old 12-15-2004, 10:14 PM
Droptopws6's Avatar
Cam lube is old school, pre roller lifters
Old 12-15-2004, 10:36 PM
code4's Avatar
I used this tool I got from NAPA. It looks like a typical air blower but has a long rubber tube connected to it. You stick the tube in a cleaning solvent jug and connect your air hose to the sprayer. It mixes the solvent with the air and sprays. Worked great for getting inside the cam. I use it to clean all kinds of parts. It cost just a few dollars.
Old 12-16-2004, 12:37 AM
TT-TECH Veteran
Inspector12's Avatar
GeorgeC and I do the same thing if you don't probably nothing would happen, but why take the chance. You could get the one they didn't get all the metal shavings etc off of. $2 can of brake cleaner will give you piece of mind. Good luck!
Old 12-16-2004, 08:07 AM
RAN
RAN's Avatar
Don't need cam lube on roller cam. Use engine oil to lube.
Old 12-16-2004, 08:25 AM
Raise's Avatar
cam lube/motor oil....either way....the key is to coat that ***** with it
Old 12-16-2004, 08:26 AM
marc_w's Avatar
Cleaned mine with WD40. Used a gun cleaning kit to clean the inside of the cam too - there was a lot of junk in there. The outside of the two cams were fine. Nothing came off on the rags I used on either cam.
Old 12-16-2004, 08:38 AM
LS1Tech Sponsor
hellbents10's Avatar
Clean it lube it and stick it in........Oh wait we are talking about cams, opps.lol!!
Clean with ample amout of brake clean (love that stuff). Compressed air to blow it off. Then lube it up with some motor oil. Put in carefully and don't F'up the cam bearings.
Old 12-16-2004, 09:03 AM
Raise's Avatar
[QUOTE=hellbents10]Clean it lube it and stick it in........Oh wait we are talking about cams, opps.lol!!
Quick Reply: Do you 'clean' a new cam before install?
