valvespring experts, jump in if u can
LS1Tech Co-Founder
Any springs that sound like this out there?
-450 open/155-160 closed
-Good for 600-630 lift cam
-I'm running .100 longer valves
-Looking to stay at 1.46 diameter springs
I was looking at the KMotion 750's, but they are only rated to up to 600 lift?
Any thoughts?
Any thoughts?
1 Post
Any thoughts?
Any thoughts?
Ed
1 Post
1.80 ish?
How do I put this???
I have what I "think" would fit the criteria but I'm not supposed to tell you that on these forums, right?
Ed
Suspended Sponsor Account
So far the Comp 977's are looking interesting.
coil bind at 1.195
with only .055 clearance getting close if pushed to .630ish, though of course you can adjust the installed height.
1 Post
Could be the beginning of a great alliance (cue the music).
My cam is:
236/246
598/632
My cam is:
236/246
598/632
1.465 OD Outer Spring Packages
PS3:
150-155# @ 1.800
335-340# @ 1.300
375-380# @ 1.200
.625" max lift recommended
Gen-3:
170-175# @ 1.800
350-355# @ 1.300
390-395# @ 1.200
.640" max lift recommended
Gen-4:
190-195# @ 1.800
350-355# @ 1.300
405-410# @ 1.200
.650" max lift recommended
If you could clear a 1.550 OD spring, there are more options.
Ed
