oil pressure
oil pressure
First off I am not sure if this is in the right place or not, but here goes. I swapped to an ls6 intake today and in the process broke my oil pressure switch. I went to orielly's and got a new one. Now the oil pressure reads higher than it did before. Any ideas on this? Did the intake cause this, or did the new switch cause this?
I broke mine off changing to a LS6 intake too. I bought one from the GM dealer and my oil pressure is the same as it was before. I did it with my cam swap and replaced the oil pump pick up tube O-ring also. I can't see any reason why the Intake would cause increased oil pressure. How much more pressure do you have than before?
