FM13 is in!!!!!! First impressions
Old 01-05-2005, 12:59 AM
BLASTER's Avatar
Thumbs up FM13 is in!!!!!! First impressions
Just finished the install today and fired the bitch up. My first cam install and I encountered almost ever snag possible but as soon as the first 5 seconds were over where I had to watch the oil pressure like a hawk, I was happy. I can't get over how well it drives on the stock tune. I honestly thought woud be lopeier and am kinda disappointed it isn't loader/choppier. It hunts for idle frequently but I help it along by keeping my pinky toe on the gas at times. It eventually finds it at 700RPM. I am using stock rear gears with this and don't have any trouble. When I do have stable idle I can leave at 900RPM without a hickup. It does lug/shake/hickup if I go below 1300 RPM in the higher gears at low speed but that is expected.
Important questions, should I raise the idle to maybe 900RPM and drill the TB hole. What size should I start off with? I used a drill bit to size it up and I think it was close to 9/64" or something.
Old 01-05-2005, 01:16 AM
That's what she said...
TheBlurLS1's Avatar
if you raise the idle, you will hear less lope
get a good tune and it should idle like a champ
i'm looking at a futural cam or maby the tsp torquer. hope everything turns out good for you!!
Old 01-05-2005, 01:34 AM
BLASTER's Avatar
I love the chop. Go figure. I am hoping for a tune real soon. Fingers crossed for 400+ hp
Some Lessons Learned
Old 01-05-2005, 01:40 AM
silverbeast's Avatar
Is your cam a 114 or 112? I have a 112 + 4 i cant wait to hear it! Congrats on your install.
Old 01-05-2005, 03:08 AM
pdd
pdd's Avatar
congrats
Old 01-05-2005, 04:13 AM
Black02SS's Avatar
Set the idle at 800 and she will run perfect. Don't need to drill the TB just adjust the set screw on the TB.
Old 01-05-2005, 05:08 AM
BLASTER's Avatar
It's a 112 + 4. I have two videos when I first started it up but it actually blurrs the microphone on my camcorder and makes it all static-y.
I will try playing with the set set tomorrow if it ever stops raining, Thanks.
Will it ever stop hunting/sweeping for idle on the stock tune? Or is there no stopping this? Thanks
Old 01-19-2005, 08:15 PM
ulySSes's Avatar
So whats new? Times, dyno, vid yet? ttt 4 u.
Old 01-19-2005, 08:21 PM
Mike98WS6's Avatar
The FM13 is a nice cam. I can't wait to see some dyno #'s.
Old 01-19-2005, 11:16 PM
BLASTER's Avatar
No tune or numbers yet...Should be getting a tune on Friday or at the least a dyno by Saturday.
I uploaded the following clip on my webpage. It is very large and was taken at the first startup so I had trouble knowing how to get it to idle. I'll try and get another one soon.
F13 video
It is also on my cardomain site.
So, I am hoping for 400+ on the dyno. Think I can amass 40+ HP from the cam and a tune???? Whenever I see someone break 400 I never see where they were before the cam. Would be nice so I could maybe guage myself.
Old 01-20-2005, 12:22 AM
matts22's Avatar
From the results I have read about, you should be right at 400 rwhp. It all depends on the dyno. Some are a little higher, some a little lower. With a decent tune though, I would think 400 or even 410ish should be possible.
Old 01-20-2005, 03:23 AM
BLASTER's Avatar
I hope so. 410 is what I want but anything over 400 i will be grateful. i will be disappointed if i don't get it and can already see myself upgrading to a bigger bumpstick.
