Comp R lifters??
Comp R lifters??
What is the main difference between the Comp R lifters and stockers?? I heard that they're the same thing just not as suseptable(sp?) to collapsing. Any info you may have is appreciated.
Damn... that good huh?? What's the problem with them other than noise?? Are they hard to set??
Comp Rs aren't the only option for a high performance lifter- you can go with Morels ($450) if you want to upgrade from the stockers. Pricey, but they've been tested to all extremes and are extremely well made.
Ben
Ben
I see what your saying. I tried searching and all I got was anything with "Comp" listed. Let me tell ya I got a ton of those. Thanks.
Originally Posted by LSUxBlake
They're a pain in the ***, they dont work right if set to the specs that Comp tells you to set them at, they're noisy. I'm going back to stock.
i installed them on my rebuild and set them to to the specs comp told me, they are noisy as anything cant even here my cam over them, i hate them i will be switching them this summer
I was told to go between 1/8" to 1/4", more toward 1/4", on my preload. I did not measure it with an indicator but was told by Jason that this would be the key with the T&D Rockers. I guess I'll see this weekend.
LS1Tech Co-Founder
I run a set and am making 738rwhp... but some shops say that you need to run more spring pressure to make them work.
I have been running a set of Crane doubles and am switching over to a set of Comp 977's to address what might be some valve float for me at 6500+. Prior to this new cam I was pulling to 7000 with no float at all and my valvetrain was not overly. I do think that running a cam with fast lobes mikght be noisy with Comp R's but I'm not sure. When I had a 422ci iron my comp s1 was noisier than my older lunati 242/242/114 cam.
I remember the only problem with the Comp R's was that you couldn't get the pre-load set properly with Yella Terra Rockers. You have to run adjustable rockers in order to get the pre-load right. But once the pre-load is set right you won't have any issues.
