If you installed Comp Cams 'R' lifters, please post here.
Old 01-14-2005, 08:55 PM
DavidNJ's Avatar
Default If you installed Comp Cams 'R' lifters, please post here.
Several people in several threads have complained about these lifters, other says they are great. Several engine builders have sung their praises also.
However, there is also the comment that Comp instructions are wrong and their backyard builder support is not up to the standards of their engine builder support.
So...if you installed these lifters, especially if they are working well after the install, can you...please...pretty please with sugar on it (my mother always used to say that)...post the details of your installation on this thread. That way we would have a comprehesive set of instructions and pitfalls in the Comp Cams 'R' 875 lifter install.
Thanks,
David
Old 01-14-2005, 09:01 PM
98 Silver Bullet's Avatar
I installed them and have had no problems. I had custom length pushrods made to give me about .005" preload.
Old 01-14-2005, 09:52 PM
SSINFUL's Avatar
Thanks,
David
They're pretty basic (depends on yer meaning of "basic"). Just install 'em in the valve lifter guides like stock.
Remove head.
Remove lifter guides & lifters.
Reverse as required (gaskets, lube, torqueing reqs, etc, etc)
I have the "R"s. No problems here.
Old 01-15-2005, 01:48 PM
DavidNJ's Avatar
Crane posts these lifter preload instructions lifter preload instructions. How do they differ from the Comp 'R's?
Hydraulic Lifters FAQ
Hydraulic lifters have been the choice of the automotive industry for many years for several good reasons. when compared to a mechanical lifter, the hydraulics are:
Quieter.
Low maintenance.
An ability to adjust for thermal expansion of the engine.
Built in shock absorber, eases stress on valve train.
“Bleed Rate” can be designed to accommodate different engine RPM ranges.
Today’s modern engines all use either the standard design hydraulic lifter or the new low friction, high performance hydraulic roller design. Hydraulic lifters are the best for street applications, high performance, and mild racing applications where low maintenance is a primary concern.
What is the difference in the design of a Hydraulic and Mechanical Lifter?
Basically, the hydraulic lifter pushrod seat is moveable, the mechanical lifter seat is not. Both lifter types look the same from the outside, with both having pushrod seats held in by a retaining lock. The pushrod seat in a mechanical lifter usually registers upon an internal step inside the lifter body preventing it from moving (thus it gets the nickname “Solid Lifter”). What’s below the pushrod seat in the hydraulic lifter is a different story. Its pushrod seat is not restricted by a step, but instead sits on top of a moveable hydraulic mechanism which acts like a tiny hydraulic pump. Below this mechanism is valving and a spring to produce an upward force, moving the pushrod seat upward against the retaining lock.
What is Hydraulic Lifter Preload?
Mechanical cam designs require a running clearance or valve lash; hydraulic lifters are just the opposite. When the rocker arm assembly is properly torqued down into position, the pushrod must take up all the clearance and descend into the hydraulic lifter, causing the pushrod seat to move down by .020” to .060”. The distance that the pushrod seat moves down away from the retaining lock is the “Lifter Preload”. The hydraulic mechanism requires this precise amount of “preload” for it to do its job properly.
What happens if the amount of Hydraulic Lifter Preload is wrong?
If clearance exists between the pushrod and the seat in the hydraulic lifter, after the rocker arm assembly has been torqued down, you will have no lifter preload. In this case the valve train will be noisy when the engine is running. All of the hydraulic force produced by the lifter will be exerted against the lifter’s retaining lock, and this could cause the lock to fail.
If the opposite occurs and the pushrod descends too far (more than .060”), then you have excessive lifter preload. In theory, a hydraulic lifter can pump up whatever preload you put into it, therefore with excessive preload, as the engine RPM and oil pressure increases, the hydraulic mechanism will pump-up the pushrod seat. This will cause the valve to be open longer and lift higher. This will decrease the cylinder pressure, lowering the performance of the engine. If the preload is excessive it may cause “backfiring” from the engine. How to correct this situation will be explained in the next sections.
When rebuilding an engine, what can cause Lifter Preload to change?
Almost anything can affect lifter preload. If you do a valve job, surface the block or heads, change the head gasket thickness, or buy a new camshaft, the amount of preload can be affected. Sometimes these changes cancel one another out and your preload stays the same; this is more by luck than design. This is why you must always inspect the amount of preload the lifter has when reassembling the engine and be sure it is correct.
Fast and Easy Way to Check Hydraulic Lifter Preload when using Non-Adjustable Rocker Arms
With the cam, hydraulic lifters and pushrods in place, install your rocker arm assembly. Use the prescribed method in your repair manual and torque down all the valve train bolts in the proper sequence. Pick a cylinder that you are going to check. Hand rotate the engine in its normal direction of rotation until both valves are closed. You are on the compression cycle for that cylinder. (At this position the valve springs are at their least amount of tension making the job a little easier to do.)
Wait a few minutes, allowing the lifters to bleed down. Now, lay a rigid straightedge across the cylinder head, supporting it on the surface of the head where the valve cover gasket would go. Using a metal scribe and the straightedge, carefully scribe a line on both pushrods. Now carefully remove the torque from all valve train bolts, removing any pressure from the pushrods. Wait a few minutes for the pushrod seat in the hydraulic lifter to move back to the neutral position. Carefully scribe a new line on both pushrods.
Measure the distance between the two scribe marks, it represents the amount of lifter preload. If the lines are .020” to .060” apart you have proper lifter preload. If the lines are the same or less than .020” apart you have no or insufficient preload. If the lines are further apart than 060” you have excessive lifter preload. To bring your preload into tolerance, use one of the methods described in the next section if necessary, or call the Crane Tech Line for assistance (386/258-6174).
Methods to Adjust for Proper Hydraulic Lifter Preload
There are several different methods for increasing or decreasing the amount of lifter preload, depending on valve train design and how the rocker arm is held onto the cylinder head. Keep in mind that the automotive manufacturers have made changes to the valve train over the years. What may work on one year’s engine may not work for another, even though they are basically the same engine. There is one method that universally works on all these engines, change the pushrod length! Use a longer pushrod to increase preload, a shorter to reduce preload. Crane offers various length pushrods and offers custom length pushrods also.
Using Adjustable Rocker Arms to set Hydraulic Lifter Preload
The easiest method to arrive at proper lifter preload is when you have an engine with “Adjustable Valve Train”. Unfortunately, since 1967 most domestic engines, with the exception of small and big block Chevrolets, have been made with non-adjustable rocker arms. The Crane Catalog shows you several ways of converting your engine to an adjustable rocker arm system. The following sections will describe how to set the preload with adjustable rocker arms.
Hydraulic Lifters Can Be Adjusted at Any Engine Temperature
Since hydraulic lifters can compensate for thermal expansion of the engine, the adjusting can be done with the engine cold; hot adjustment is not necessary.
Adjusting Hydraulic Lifters for Proper Preload
In order to adjust the preload the lifter must be properly located on the base circle or “Heel” of the lobe. At this position the valve is closed and there is no lift taking place. You will need to watch the movement of the valves to determine which lifter is properly positioned for adjusting.
1. Remove the valve covers, and pick a cylinder you are going to set the preload on.
2. Hand rotate the engine in its normal direction of rotation and watch the exhaust valve on that particular cylinder. When the exhaust valve begins to open, stop and adjust that cylinder’s intake rocker arm. (Why? Because when the exhaust valve is just beginning to open, the intake lifter will be on the base circle of the lobe, the correct position for adjusting the intake.)
3. Back off the intake rocker arm adjuster and remove any tension from the pushrod. Wait a minute or two for that hydraulic lifter to return to a neutral position. The spring inside the lifter will move the pushrod seat up against the retaining lock if you give it time to do so. (If you are installing brand new lifters they will be in the neutral position when they come in the box.)
4. Now spin the intake pushrod with your fingers while tightening down the rocker arm. When you feel a slight resistance to the turning of the pushrod, you are at “Zero Lash”. Turn the adjusting nut down one half to one full turn from that point. Lock the adjuster into position. The intake is now adjusted properly.
5. Continue to hand turn the engine, watching that same intake. It will go to full open and then begin to close. When it is almost closed, stop and adjust the exhaust rocker arm on that particular cylinder. (Again, when we see the intake almost closed, we are sure that exhaust lifter is on the base circle of the lobe.) Loosen the exhaust rocker arm and follow the same procedure described before in steps 3 and 4 to adjust this rocker arm.
6. Both valves on this cylinder are now adjusted, and you can move on to your next cylinder and follow the same procedure again.
Do Hydraulic Lifters Need to be Primed with Oil?
Many people mistakenly believe that hydraulic lifters must be soaked in oil overnight and be hand pumped up with a pushrod before installing into a new engine, however this is not necessary. In fact, this could cause the lifter to act as a “solid” and prevent obtaining proper preload. What is very necessary is the priming of the entire engine’s oil system before starting up a new engine for the first time. This is done by turning the oil pump with a drill motor to force oil throughout the entire engine. Crane Cams offers oil pump primers for Chevrolet and Ford engines.
Old 01-15-2005, 04:10 PM
felton316's Avatar
No problems with mine. Head shaved .030, 7.40" pushrods, and an aftermarket cam. Torqued to the normal 22 ft-lbs, like stock.
Old 01-16-2005, 10:37 AM
LS1TECH Sponsor
Steve Burger's Avatar
No problems here. 7.35 PR and .030 shim for preload.
Old 01-16-2005, 11:26 AM
DavidNJ's Avatar
Here go the questions:
Comp Specs .002-.004. So, Steve H, you are using just a very, little more. I'm usually pretty happy when the valves are within .001 after I tighten the girdle.
However, Steve Burger, .030? Did you mean .003?
And felton316, how much preload is 22lbf-ft of torque?
Thanks,
David
P.S.
How is your tapet noise?
Old 01-16-2005, 12:00 PM
Senior Member
Country Boy's Avatar
I have them and they work perfect. However.... DO NOT go by their "recommended" preload. I bought big dog adjustable rockers, set the preload perfect and had all kinds of problems. IE. valve float. I switched the whole valvetrain (bought new rockers and pushrods) and the preload ended up being ~.010 and they are now perfect.
Old 01-16-2005, 12:12 PM
71CamaroLS1's Avatar
I suspect that lots of people who have problems with them are getting hot and cold preload specs confused. The R's want .002-.004 preload at operating temps. Because the aluminum block and heads expand more under heat than the steel lifters and pushrods, hot preload will be less than cold preload by about .006 to .008. So if you set cold preload less than about .010, you run the risk of hot preload going to zero, which will cause lots of problems including plenty of valve noise and eventual failure.
Old 01-16-2005, 12:14 PM
LS1TECH Sponsor
No .030 is right. I could use a 7.32 PR and get the same result. This was right for my car and cam. Others wil be different.
Old 01-16-2005, 03:53 PM
Louis's Avatar
Bingo. Someone sticky this mans reply. I am not going to feed info to yall via spoon, but the piston, when warm is actually in the hole
Old 01-17-2005, 09:07 AM
SAM98WS6's Avatar
Work like a champ..
soak in mineral spirits to remove cosmolene...soak in oil overnight
Check pushrod length...
.008-.010" preload with a dial indicator..cold..1.75 Pro Mags
Old 01-17-2005, 10:13 AM
SmaknaSS's Avatar
Their not worth the trouble to set up in my combo in my opinion. If I had a high lift cam and could get to the balancer pully easier then I would think about using them
