Small duration (less than 220) comp X-er lobes?
I've been using the attached lobe sheet to order comp cams with. The X-er's only go down to a 220 duration on this sheet. Does comp offer a 216 or 218 X-er lobe? Also, if anyone has the newer lobe master they can post or email to me, I'd really appreciate it.
Originally Posted by LOnSLO
You can get the master catalog on Comp's site. BTW - You can get most any hydraulic lobe in their list made to fit an LS1
I have heard about taking another hydraulic roller lobe and having it ground on a LS1 blank, but how does that effect the "base" specs of the lobe?
For example, if I took a Xtreme Energy Comp lobe #3314, which is a 224 @ .050/ 276 advertised/ 145 @ .200 and a lift of .570 with a 1.7 rocker when it is ground on a small block chevy hydraulic roller blank and had that ground on a LS1 blank. What would the specs change too?
Originally Posted by gomer
The smallest X-er they have listed on their online catalog is the 220.
It's a lobe they use for renegade racing.
LS1 Tech Administrator
You should check into Cam Motion. They make .588 lift lobes in the 21x range. Mighty nice and rev to the moon.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
nothing will change aslong as you use a 3314R "R" masters are for the LS-1 bearing journal 2.165" If you used a SBC 3314S it will change. The SBC uses a smaller bearing journal. If you used an "S" master on an LS-1 the lobe would "grow" about 3 degrees of duration at .050"
Thanks,
Brian
Thanks,
Brian
Here's some extremes...from Comp
Lobe#, Dur. @ .006", .050", .200", & Lift w/1.7 rocker
2124 265 215 142 .629"
2125 269 219 145 .632"
2126 273 223 149 .636"
2127 277 227 153 .639"
2128 281 231 156 .643"
2129 285 235 160 .646"
2130 289 239 164 .649"
2131 293 243 168 .653"
2132 297 247 171 .656"
2133 301 251 175 .660"
2134 305 255 179 .663"
2135 309 259 183 .663"
2136 313 263 186 .663"
1 Post
There are some 214*-215*-216*-218*-219* that are similar to XER. Some more aggressive, some a little less...
Ed
1 Post
Originally Posted by Unaffiliated Racing
those are not typical xtreme energy lobes...those lobes are not made to be for public use
Huh?
I have used them before...
Guess I'm not the public Brian???
Ed
1 Post
Ed...I know what you use .....Those lobes were meant to be propritery
You "may" know what I use over there at Comp but they aren't my only vendor...
Remember Mark C. and his "loose lips"? Back when he was the Racer Rep, I had to search around for a place that wouldn't "share" the R&D...
You should call one day so we can BS for a while.
Ed
You don't have to worry about that. My reputation and expierence speaks for itself. Tons of people use me for cam knowledge just like yourself. BTW for all intents and purposes I never said I worked for Comp..if you catch my drift.....
