Would this pic indicate burning coolant?
Old 01-18-2005, 06:45 PM
Spellbound's Avatar
Default Would this pic indicate burning coolant?
I also found milkshake oil in the TB, dipstick tube, top of oil cap, and the catch can was 3/4's full. Drained some oil out of the pan and it looked ok, no milk shake.
This is what I mean by milkshake, lol ^^^^
Old 01-18-2005, 07:01 PM
TripleBlackRamAirT/A's Avatar
Thats exactly what the oil I just drained out of my air compressor looked like.
Old 01-18-2005, 07:02 PM
buffman's Avatar
are you driving your car long enough to allow it to reach it's operating temperature? Say around 15-30 minutes? The milkshake stuff, from what I've been told is pretty in those areas because that's the coldest place the engine oil reaches causing condensation, and the formation of that gooey stuff.
Old 01-18-2005, 07:03 PM
Smo's04Gto's Avatar
WOW that'a nasty looking,I wounder now many times you'll have to flush out the system to remove the oil.
Old 01-18-2005, 07:16 PM
LS1Maniac's Avatar
I don't know what that is but it's NASTY! I had some orange-ish stuff in the radiator of my old Camaro but it all went away with a good flush.
Old 01-18-2005, 07:25 PM
Spellbound's Avatar
Car definately reaches operating temps....Any ideas on the white stuff on the pistons?
Old 01-18-2005, 10:32 PM
buffman's Avatar
I'm not sure...
Old 01-18-2005, 11:14 PM
Ferocity02's Avatar
I think that's how they make mustard
Old 01-18-2005, 11:15 PM
flippincamaro's Avatar
usally when you are burning coolant whichever cyclinder is burning it appears to be really clean it is like steam cleaning the piston and valve area, that doesnt look like a coolant burning in that cyclinder but i am not a expert just have a lil knowledge on burning coolant
Old 01-19-2005, 04:07 AM
Dustin 98TA's Avatar
That is correct, if it were burning coolant, the piston would be clean. I wouldnt worry about the deposits on the piston, it looks like normal combustion.
I would look closely at the head gaskets, to see if one has been leaking water into the oil. You can usually notice a trail from the water hole to the oil return. I have seen this plenty of times on the LS1 engines.
Old 01-19-2005, 09:26 AM
tye698's Avatar
it looks like detonation. maybe just the pic..but my pistons looked like that and they detonated alot
Old 01-19-2005, 10:46 AM
zamboxl's Avatar
that fussy white stuff sure looks alot like aluminum rust( well oxidation).
Old 01-19-2005, 11:07 PM
Spellbound's Avatar
to the top
Also someone told me you can tell by the oil pattern on the top of the piston whether an oil ring is bad or the valve guides are bad. Oil on the outside of the piston= bad ring, oil in the center, bad guide. Is this true?
Quick Reply: Would this pic indicate burning coolant?
