how close to rated max lift/coil bind have you ran your springs?
Old 01-19-2005, 01:10 AM
GrannySShifting's Avatar
Default how close to rated max lift/coil bind have you ran your springs?
And what springs were they, how they fare - did the pressures hold etc?
Old 01-19-2005, 01:54 AM
goober35's Avatar
918's 590 lift they max at 600. Had them 9k miles. I know of people running them at 599 lift also but i am not sure on how many miles.
Old 01-19-2005, 01:57 AM
I can shift faster than you.
Jason99T/A's Avatar
The Comp 918s handle alot more lift than .600. Installed at 1.800", they will easily take a .620" lift cam.
Old 01-19-2005, 02:38 AM
goober35's Avatar
Damn and i was scared to take them to 590. I feel like a puss.
Old 01-19-2005, 05:25 AM
Nate_Taufer's Avatar
I agree. The 918's don't even reach coil bind until .750 as tested by my drunk buddy but it also has a lot to do with ramp rates. More aggressive ramp rates are more at home with a dual spring.
Old 01-19-2005, 09:33 AM
94form2000z's Avatar
ran the Comp 987 duals @ .588 lift with an instal heigth of 1.85
Had around 15k on them when I returned to stock.
Old 01-19-2005, 11:58 AM
yes been over .620 lift with the 918s here
Old 01-19-2005, 12:48 PM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,099 Likes on 721 Posts
Crane 99893's with 595/598 lift fine.
Crane 99893's with 598/632 lift may be gettings some float at 6500+ so trying Comp 977's with more spring pressure.
Old 01-19-2005, 09:19 PM
what lobes john?
Old 01-20-2005, 02:40 AM
sr71bbjr's Avatar
isky's here.252 261 651 651 114lsa.I had to buy a retainer that was half the thickness
as the standerd to keep from bind.
Old 01-20-2005, 02:47 AM
PREDATOR-Z's Avatar
I like to give at least a .015 margin.
