Stock pushrods and LS6 cam
Old 01-23-2005, 09:52 PM
CRASH 02's Avatar
Question Stock pushrods and LS6 cam
Just wanted to see how many of you are running stock pushrods with an LS6 cam. I know you are supposed to run a longer pushrod, but I know of a few people that are still running stock pushrods.
Old 01-23-2005, 10:26 PM
jd13's Avatar
Longer pushrods with a LS6 cam are not necessary.
Old 01-23-2005, 11:25 PM
SnakeOiler's Avatar
The 02+ LS6 cam has a smaller base circle, why wouldn't you want to use a longer push rod in order to keep the geometry correct?
Old 01-24-2005, 05:51 AM
cbota's Avatar
I figured it out about a year ago so I dont remember the exact numbers, between the stock PR and longer Pr, 1 would be a little short and 1 would be a little long, it was closer with the stock PR and I felt that shorter was better than longer, just my thoughts
Old 01-24-2005, 06:02 AM
PREDATOR-Z's Avatar
the difference is .035. If you install 7.40 (aftermarket stock) the diff will be .015.
If you use stock LS1 7.38, the diff will be ~.035
Ideally 7.420 should be your p-rod length.
Old 01-24-2005, 07:27 AM
GTO_Scott's Avatar
If you have 2002-2004 LS6 heads with stock valves, I believe the valve stems are slightly longer and match the smaller baseline of the cam.
Old 01-24-2005, 01:32 PM
TNormZ28's Avatar
I used stock pushrods with the 02 LS6 cam in one of my cars. It was fine.
Old 01-24-2005, 01:47 PM
oange ss's Avatar
are aftermarket pushrods recommended with a cam swap ?
Old 01-24-2005, 04:02 PM
TNormZ28's Avatar
depends on the size of the cam. I kept stock ones with my FM11. I've bounced the limiter a couple of times on accident no probs yet. I think it's if the cam is over .600 lift you want hardened ones. Might try a search for that one.
Old 01-24-2005, 05:33 PM
crow2's Avatar
We like to see the use of manley pushrods,they hardend killer pushrods! GO FOR IT!
Old 01-24-2005, 10:15 PM
ULTIMATEORANGESS's Avatar
ive been running my stock PRs for years with this cam.
Old 01-25-2005, 09:42 AM
crow2's Avatar
[QUOTE=ULTIMATEORANGESS]ive been running my stock PRs for years with this cam.[/QUOTE
I agree! stock pushrods do get the job done,but if a guy ever wanted to upgrade,hardened pushrods are great.
