View Poll Results: Ajusting Rocker Arms???
Method 1
0
0%
Method 2
0
0%
Multiple Choice Poll. Voters: 0. You may not vote on this poll
What is the correct way to ajust RR
These are after market rocker arms with poly locks no 22ft.lbs. here.
Ok this is going to be a poll to decide what is the best way to aftermarket rocker arms. Just seeing how most people on here do it. I have done it by method 1 for who knows how long.
METHOD 1 1.Turn poly lock with set screw backed out down until drag is felt on the push rod. 2.Hold the nut with a wrench and tighten down the set screw untill it hits the rocker stud. 3. take the wrench and give the rocker a 1/8th of a turn or what ever is needed according to the lifters.
METHOD 2 1.Turn poly lock with set screw backed out down until drag is felt on the push rod. 2. Turn the nut 1/8th of a turn. 3. tighten down the middle set screw and your done.
Thanks for your time!!
Joe
Joe
