CAM HELP? I need it bad
Old 02-02-2005, 11:35 AM
newLS1's Avatar
Default CAM HELP? I need it bad
When i cam the car i want a good nitrous grind and stall to go with it. INPUT PLEASE im new to this and need to get this car running good in two months so HELP guys, Im a ford man, but purchased this thing to outrun some BOYS at there own game. HELP FAST what works the best on these cars????????
Old 02-02-2005, 12:44 PM
Willwork4mods's Avatar
Cam, Stall, Bottle ... short version
With slicks on .. should net ya a mid to high 11.
Worked for me on my first setup ..
Old 02-02-2005, 12:49 PM
tim99ws6's Avatar
IIRC, you'll want a low stall to compliment the nitrous. If you want a good performing cam, and emissions arent a worry, somewhere around low 230's intake, high 230's exhaust duration...and right around .600 lift.
Any wet kit will work nice with that cam, and with the correct stall, and a good tire...you should have no problem hitting 11s all day. just make sure you get it tuned
Old 02-02-2005, 02:25 PM
TT-TECH Veteran
Inspector12's Avatar
230/236 114 with nitrous and a 3600 stall is my favorite RPM range stall.
Old 02-02-2005, 05:57 PM
crow2's Avatar
For what is worth on this,alot of people we deal with like the ZO6 camshaft~if you can stand it.The guys at NX can set your deal up right with a recommended kit or we can.Just a thought!
Old 02-03-2005, 06:25 PM
crow2's Avatar
I HAVE HAD SOME THOUGHT ABOUT YOUR QUESTION in more detail,We have had some better luck with the GM hotcam,we also would like the crane tuner!! I know the people at NX has some NEW cam grinds for nitrous applications also.The ZO6 camshaft has a higher lift than the HOTCAM,but the duration @.050 is the key in this.I hope that this helps even futher.
