Dyno results AFR 205s with BIG cam
Location: sojourning....looking for my city whose builder and maker is God.
We had our 2001 WS6 M6 dyno'ed yesterday.
It made 453/410
Scroll down on this page and see mods and links to charts of before and after install.
My 2001 Firehawk A4 cam only dyno is there as while.
It made 453/410
Numbers aren't bad by any means, but would have expected more. If the pistons were notched in the car it'd be interesting to redyno with 1.8 rockers considering the relatively mild lift of the cam. On another note, how does the car feel with that set up?
SN95 Director
what lobe series is the cam from? whats the .006/.050/.200, if you dont want it public you can PM and i'll keep it quite. im just wondering how "big" that cam is.
also the links too the dyno's dont work:
Forbidden
You don't have permission to access /22/1/50/23/208115023BLwWEd_ph.jpg on this server.
Apache/2.0.50 Server at image22.webshots.com Port 80
Forbidden
Originally Posted by hitemup9nine
A little off subject but is that cam you have in your firehawk based off the f13 on a custom lsa or is a totally different cam. Thanks. BTW good numbers
Seth who use to be at Combination Motorsports did the R & D on this cam.
Forbidden
Forbidden
It was standard. Here are the cal. not sure if you are to multiply by Relative Horsepower 98.7% or Dyno Correction Factor 1.013%, either way not more than 4 or 5 hp.
Here is the graph, I need to work on my website.
Were the heads milled any? I would have expected a little more out of that setup. If you correct it to SAE and disregard that spike at the end, it doesn't make over 450rwhp thru a 10bolt. What did the car dyno before the heads? Did you guys dyno it while it was Cam only?
I my first post I posted a link to all the mods on his car and cam only dyno. I am working now on fixing the link on that page for the charts. The heads were installed out of the box with Cometic gaskets. The CF DF Clutch grips 90% which can pull 10 to 15hp, but keeps the clutch safe.
SN95 Director
Originally Posted by Lady Redhawk
OK, I have working links to the charts on that site now. Sorry about that.
what gasket are you running? that cam is just itching for an 11.1 ratio. also, you dont happen to have an overlayy of the cam only vs heads. im curious the gain through the curve.
good man, or woman i should say
We didn't get an overlay, we were dyno tuning a bunch of cars and didn't get all the charts we wanted. But both charts are on the site for side by side compare.
SN95 Director
lol, He has the .040 Cometic gaskets which should make it 10.4 ratio. He would have to notch the pistons though if he milled the heads. He still has the stock intake manifold, and stock ported TB.
how's the MAF working out, any issues?
Originally Posted by SportSide 5.3
I thought the graph read 450/450
Nice results for such a large camshaft. I'd expected a greater loss in low end power.
whats the deck height? even using a zero deck (which it shouldnt be), i come up with 10.58 assuming -.006 to -.008 i come up with 10.7 - 10.8. whats the ICL of the cam.
