Mr Gasket .042 Head gasket...
Talked to Mr Gasket Tech dept today and they told me that their head gaskets part # 5713G & 5714G ( right & left side) are .042 compressed thickness, but are for a 4.000 bore. Other than loosing a bit of compression what are the consequences of using this gasket on a stock bore? Would quench be effected? They list these as being for 97 & up. Has anyone used these gaskets on heads that have that slot cast into them?
h/c swap on my 04 C5 and these gaskets were identical to the stockers, as far as bore diameter. difference was mls were .054 compressed and these are .042, as you stated. not sure of your slot question, but gaskets worked great for me, and it was the only part i have put on the car that was reasonably priced $18/ea. measure piston above deck subtract from compressed will give you quench. i ended up with .035
That's great news. My next question is where did you get them. I've been on-line all day looking for them. ( Sponsers,Summit,Jegs,etc) Lot of websites say they have them but when you call, they tell you they have to be special ordered with no ship date promised.
Ordered mine though our vendor [keystone] no one local had them in stock.They are for a 3.90 bore the tech you talked to was mistaken.I searched these out a month ago
and verified through mr. gasket tech vebally and thru email.
Guys......the Mr. Gasket 5713g/5714g is NOT (I repeat NOT) .042" thick!
I searched and searched, and after a huge ordeal got a set. I specifically wanted a .042" gasket to raise the comp. up to 10.5. All these are is a repackaged Victor-Reinz graphite gasket PN 5975/5976. It's IDENTICAL to the GM graphite gasket which is also a VR gasket. The uncompressed thickness is .057". Now I'm ******* pissed cause I could've got them from NAPA or the dealer way easier and cheaper!
SN95 Director
i take you you measured to confirm?
Just had to vent since these took me a week to get with the car torn apart only to have them turn out to be the same damn one I could've got at the dealer when I got the head bolts. Either Mr Gasket or one of the guys here posting about them has been smoking some bad ****.
SN95 Director
Have one right here. Mic'd the stock GM graphite, the Mr Gasket/VR and the MLS to compare. The GM and MG/VR graphites are identical except the GM has their own PN on it versus the 5975/6 stamped on the other.
just want to know for sure for future reference when this topic comes up again. which it will no doubt.
you miced them UNcompressed. they both will measure the same. i have the same VR gaskets sitting in my toolbox at work. was going to use them. but went with the MRgasket ones instead. i called VR directly about the VR brand ones. they will only compress .003-.005 at max. according to the VR tech. i had vinci mic both sets. they came up the same UNcompressed. it's all in how the material used compresses. we alos measured the stock GM head gaskets when pulled off. about .052 compressed. yes VR makes them for MRgasket.
it's the MRGasket version that's different. we also measured it at .057" thick uncompressed. but, many have measured it compressed to find it right at or very near the .042" compressed as advertised. the GM and VR will only compress .003-.005. the MRgasket will compress more. you'll just have to trust us, or waste one finding out for yourself.
You know, on a side note, the other bizzarre thing is that Mr. Gasket also has a line of MLS gaskets for the LS1. In the catalog, they're labeled as LS1 350 gaskets and are .045" thick I believe. But the bore sizes offered were like 4.135, 4.145, and 4.155?? What the hell are those for? Sounds like they need to pull their head out.
Originally Posted by smask04C5
I have used three sets on various upgrades, two sets that I measured were 3.90 bore with compressed thickness of .043, and 1fastws6 I'm not smoking anything.
