Help me decide guys-should I use ARP's or stock fastners?
I'm getting to ready to put my heads back on my motor soon-I was going to use stock head bolts but now I'm think maybe the ARP's are the way too go. There is a huge difference in price(ARP heads studs versus GM head bolts)but a payoff in convenience. The Studs will save time for future head jobs as you don't have to clean out all the bolt holes. Also I have the ARP crank bolt-I have yet to use it BUT I just read an article last night in HOTROD that stated the factory T/Y crank bolt is notorious for coming loose even with blue locktite? I personally have never seen mine come loose. Also I'm a little weary about the torque specs and the retorquing of the head bolts but Cometic told me the heads need to be torqued only once. This probably is not going to be the last time the heads on my car will be changed-If I don't make the power I want I'll be switching heads again. Let me know what you guys think or suggest-thanks!
Just for info...the factory crank bolt is not torque to yield. It only get torqued to like 30 ft/lbs after you use the old one to like 230 ft/lbs. Just because you need to replace it doen't mean it's T/Y. I've used the same bolt numerous times. You don't make the new bolt yield(strech) when you put it in.
Thank guys-I'm leaning more and more toward the ARP's. Do you guys know if the heads can be removed and installed with the studs in place on a C5? Looking at it with the heds off right now it seems like there should be no problem.
If you think any bolt doesn't stretch when torqued down, you're wrong.
And 30ft/lbs for a bolt the size of the LS1 crank bolt is, relatively speaking, "hand tight."
And FWIW, the factory crank bolt is TTY. You're supposed to *install* the balancer first whether you use the old bolt or an appropriate install tool. Then you proceed with the correct torque procedure of the crank bolt...30 ft/lbs + 240 degrees. With an ARP crank bolt -- 250ft/lbs. (numbers may be slightly off)
