LS2 oil pan fit an LS6??????????
Originally Posted by goober35
Why would u want to put an ls6 in an ls2 car. Unless you are going the other way. But yes the pan will bolt right up.
Going to put the LS2 pan on my LS6 for better baffles it supposedly has for track use in my Vette. Thanks? Any idea on the price?
MM witch ls2 pan. There is 2 out there. The one on the GTO and the one on the vette witch i asome you are talking about. As for price i have no idea. If you get it from GM it wont be cheap.
What information do you have on the LS2 pan being better for road racing?
I am building a LS6 motor for a C5 road race car and I was just looking at Accusump systems tonight. I don't really want to add the extra weight and a check valve etc. If a LS2 pan is better, that may do the job.
That's a great picture of your car Speedpup. I have only had my C5 on the track two weekends with the LS1 motor so I really don't know what kind of oiling problems I am going to have. Do you have any oil pressure drop off while racing??
Racecar
Racecar
I have an accusump I already smoked a motor. tranny, and rear in one horrible event. I have seen it drop. Tranny and diff coolers also. Info was in a GM article but someone said it holds 1 qt less now.
The LS2 oil pan holds less because of the better baffles in the pan. Yes it will fit on the motor but I don't know if it will fit in the car! Also remember the LS2 is a dry sump system so you might have some problems trying to get your oil pickup to work right if at all!
