Which Cam f10 or tr224/112
Old 02-21-2005, 05:08 PM
flawless98ss's Avatar
Default Which Cam f10 or tr224/112
does one cam produce more power than other?
Old 02-21-2005, 05:12 PM
nikejr16's Avatar
If you do a search on f10 & tr224/112 cams. you will find a bit of info.
Not trying to be a jerk or anything.
Old 02-21-2005, 11:20 PM
pdd
pdd's Avatar
F10 All The Way
Old 02-21-2005, 11:23 PM
CT Hotness
lilstephsls1's Avatar
they are both good cams. Like nikejr16 said, do a search and I'm sure you'll find dyno results on both and such. Otherwise, check the prices and maybe even wait around for a group purchase or something so you can save a few bucks on either cam
Old 02-22-2005, 01:25 PM
NBM2k2SS's Avatar
Is there a difference in power between the TR224 on a 114 lsa and a TR224 on a 112 lsa? If so about how much?
Old 02-22-2005, 01:31 PM
PREDATOR-Z's Avatar
~10 rwhp at peak depending on combo
Old 02-25-2005, 10:44 AM
ninobrn99's Avatar
from what i have seen, he is right. I am running the f10 on a 114 and it pulls hard at about 3700 rpm on up. I would consider the f11 if your going to get the f10. you may peak an extra 5-10 hp. if emissions is a problem then go with the 224. the lower the lsa the lower you powerband is. either way, you will notice a difference
Old 02-25-2005, 02:10 PM
TheBowtieboy's Avatar
You might want to define "power"......top end HP, low end torque, best mdirange, etc.
What one person wants a cam for (ie: 1/4 mile racing) and another (ie autocross or road racing) will have different power needs.
Old 02-25-2005, 02:22 PM
ulySSes's Avatar
F10 considering there's a GP right now. Why not go with the F11 instead?
