Help needed ASAP *cam swap*
Old 03-12-2005, 04:06 PM
Zinc's Avatar
Default Help needed ASAP *cam swap*
OK, off to a shitty start so far heh.
Car is up on the stands, and Im about to drain the radiator. However, that DAMN petcock valve wont budge. Any tips or suggestions? Also, 1/2 of the damn "****" that you grip onto decided to break off
Please help asap.
Thnks,
Ryan
Old 03-12-2005, 04:09 PM
greatwhite99's Avatar
you could un-clamp the lower radiator hose. Just be carefull since this is a little messy approach.
Mike
Old 03-12-2005, 04:29 PM
Ws6ik_2000's Avatar
that sucks man
Old 03-12-2005, 04:54 PM
Zinc's Avatar
Anyone else?
Old 03-12-2005, 04:57 PM
SSPerformance's Avatar
just undo the lower radiator house
Old 03-12-2005, 04:58 PM
35th SS's Avatar
use vacuum hand pump and suck it from the top of radiator by the cap.
Old 03-12-2005, 05:31 PM
Zinc's Avatar
Alrighty, got it done. Now im tackeling the damn coil-pack bolts. heh. They are coming slowly but surely. Thanks for the quick help guys.
Ryan
Old 03-12-2005, 08:48 PM
why are u taking the coil packs off just un hook them from the harnesss and unbolt the vavle cover......
Zinc's Avatar
Im just following the ls1howto directions:dunno:
Old 03-12-2005, 08:59 PM
i take it its gona be a very long cam swap
Old 03-12-2005, 10:10 PM
99ssleeper's Avatar
heh....noob cam swapper...
good luck with getting the balancer off/on and oil pump tube bolt out/in. The fun has just begun!
Old 03-12-2005, 10:54 PM
01_SuperSlow's Avatar
True that!
Old 03-12-2005, 11:24 PM
RIP April 14, 2008
Diolar Magnum's Avatar
Location: the land where cars repeatedly hit my bumper when I'm in the store...
oh great sounds like some fun **** to look forward to.
Old 03-12-2005, 11:39 PM
99ssleeper's Avatar
Just to clarify, I know Zinc. He asked for my help, but I cant be home this week...
Be sure to post your thought on the swap Ryan
Old 03-13-2005, 12:32 AM
LSONE's Avatar
once you get to the oil tube, please stick a wash cloth or something in the oil pan to catch the nut when (not if, trust me) it falls. would have saved me ~5 hours
Old 03-13-2005, 12:44 AM
DanZ28's Avatar
Agree'd!
Little trick I do is put some safety wire on the bolt after I undo it a few threads, wrap it around and twist it like a bag tie. It won't fall in the oil pan I guarantee you...I still put a rag in there anyway though
Dan
Old 03-13-2005, 01:06 AM
HotRod68Camaro's Avatar
Few tips iv got from doing my cam swap. I am just about to bolt everything back up.
1) grab a pen magnet when you are loosening the pickuptube bolt and just stick the magnet on the end of the bolt.
2) when putting the new oil pump back on, stick a screwdriver between the pickup tube and the main caps and pry it towards you. i spent about 30 min tryin not to pinch the o-ring and eventually figured out to use the screwdriver. (i had the oil pump apart b/c i had just got done porting it and was centering it on the crank. so i could actually see how the o-ring was getting pinched.
Old 03-13-2005, 11:14 AM
Byter's Avatar
My tips:
1. Get an expandable pen magnet. You'll use it a gazillion times!
2. Get ready for a fluids (coolant, oil, PS fluid) mess. Oil Dry and a couple of old blankets will keep things clean.
3. Label everything. Put each set of hardware (e.g. the timing cover bolts, intake bolts, etc...) in its own baggy and place a piece of paper in it with it's name. It makes re-assembly so much easier.
4. Get a set of metric "ratchet" wrenches. You know, the kind that you put over the nut or bolt and ratchet back and forth.
5. I don't know your setup, but if you are running tight compression (i.e. had the heads milled), check PTV clearance. Make sure the cam matches the cam card by degreeing it (even if you use a non-adjustable timing gear, you still want to check).
6. Learn as much as you can beforehand about, PTV clearance, valvetrain geometry, preload, etc. It's better to have this knowledge BEFORE you put it back together than to find out afterwards, you may have screwed something up.
7. Since you're a newbie (like I was), the chances of you making a mistake are pretty good. Get the ARP head studs in case you have to take the heads back off again. The cost of the studs is roughly the same as two sets of GM head bolts.
8. Take your time. Don't do any shortcuts because they will always bite you in the a**. You will run into a lot of small headaches. There's a guy on here now having a hard time getting the crank pulley off. You will run into these kind of things too, so be calm, take your time and attack each one with some thought.
Good Luck!
Old 03-13-2005, 12:49 PM
Zinc's Avatar
Well, Ive got a guy coming over whos done the swap himself 5 times, so Im not THAT worried. But thanks for all of the great tips guys! ill throw up a short vid or two once its in.
Ryan
Old 03-13-2005, 01:02 PM
ssheets's Avatar
[note to self]
plan a few days of vacation and buy a pack of bandaids ...I think I've got everything else
