can some1 help me w/ valve events??
all mods in sig.i think ive FINALLY made my decision for my new cam im gettin next week.ive ruled out ALL HUGE cams;since im not much of a track guy.im looking very close at the F9;its a nitrous cam , i know.and ill be sprayin MAYBE 2-3 times a week.but it is a daily driver, and it will see more n/a driving.i dont reaaly mind the street manners it has.i wouldnt mind it being a little on the choppy side.but my main goal is to run a very good TQ curve.im a TQ junkie.so im either thinkin this cam or a G5X2 or maybe G5X3.if i can get some1 to run the v.e. on the F9 and the G5X3, that would be great.thanks boys.
p.s. the F9 is 232/236 .585/.600 114lsa...maybe some1 else knows the X3's specs.TIA.
I have a version of dyno sim amd when I want to look at valve events I just pop it into the calculator on it. Gives a nice visual representaton of the lobe as well.. and helps me see ramp rates to really pick a spring to use instead of just going by the ol "this spring works for this cam"...cause a 224 cam might be good for a 918...but a fast ramp 224...918's might not be quite enough(example being if it were more like a solid roller lift and ramp rate...not that a 224 would be a solid roller...but if it were an extreme ramp rate...I would be able to see it better)
Originally Posted by jrp
what lsa and icl's are you looking at?
i want it to have good lope,so i would think a 112 lsa.im going to do G5x3....i dont know its centerline.
SN95 Director
thats what i use , quick and easy.
you planning on flycutting? im not sure if the x3's have the same 4* advance as the x2's.
no.no fly-cutting.just all bolt-on's and a hefty cam(and maybe a lil 100-150 shot ).i hope they dont have any advance ground in;that wont be good for the spray.
SN95 Director
