oil presure problem after h/c swap
Old 03-26-2005, 10:03 AM
SSPerformance's Avatar
Default oil presure problem after h/c swap
when i start the car when its cold it makes 45pis at idle. after it warms up it goes down to 30psi after driving it a bit sitting at a light it will be on top of the lil red bars at like 5psi but driving it at 1500rpm iits at 30psi when i rev it to redline it goes like 45psi. why when im sitting at a light will it drop down to liek 5psi thenthe check gauge light comes on
Old 03-26-2005, 02:47 PM
crainholio's Avatar
I'd guess the cam bearings got dinged up during the cam swap, that would account for the reduced pressure.
Old 03-26-2005, 03:34 PM
DaddySS's Avatar
Did you swap the pump when you did the cam? What was the pressue before, how many miles on it?
Old 03-26-2005, 04:34 PM
presure befor was 35 at a hot idle i just took it apart and the oil pump o ring was fine i replace the oil pump with a ported ls6 from thunder
Old 03-26-2005, 04:41 PM
im thinking it mite be the op sensor is there any where on the block to hook up a manual gauge
Old 03-26-2005, 07:43 PM
Lvmyz28's Avatar
if you aren't carefull when you put the oil pump back on you can slice a chunk out of the o-ring. Been there and done that. I had the exact same problems you are experiancing and sure enough. When I took the pump back off a chunk was missing out of the o-ring!
Old 03-26-2005, 08:27 PM
DaddySS's Avatar
I'd say most likely a problem with the o ring/pump install.
Old 03-26-2005, 10:11 PM
i took the oil pump out befor and the o ring was perfect and went back on perfect. i think the spacer used from the double rommer timing cain was upside down only letting haf the oil thro to the block from the pump... we will see when i get my water pump gasgets this week
Old 03-26-2005, 10:39 PM
Tally TransAm's Avatar
did you use a new o ring?
Old 03-26-2005, 10:43 PM
of course
Old 03-27-2005, 08:06 AM
DaddySS's Avatar
Didn't know the spacer could do that, good info. Thanks and keep us posted.
Old 03-27-2005, 08:38 AM
waiting on water pump gasgets from thunderracing
Old 04-01-2005, 07:41 PM
well i change the oil after the gasgets got here then put some 10w40in took it out for a ride and k bang spun a bearing
Old 04-01-2005, 07:58 PM
gwj
gwj's Avatar
Location: Live Oak, FL - in the woods where the creatures lurk.
That sucks! I was reading the thread and was gonna say I wouldn't put much trust in the stock gauge, but apparently it was working for you. Rod bearing, I take it?
Old 04-01-2005, 08:08 PM
Lvmyz28's Avatar
That sucks man.
Old 04-01-2005, 08:35 PM
o well time for some more CI
Old 04-01-2005, 09:05 PM
well this is what it did befor it blew change the oil started her up and she made 30psi and very slows as it got warm made it way down to zero took a goof 20mins
Old 04-01-2005, 09:07 PM
also 108k miles on the motor dident help
