Which GM head gaskets, 241 head on a 1999 LS1 block and most compression?
First off, yes I have read the LS1 CC compression sticky..
I am putting a set of ported 241 castings on my 99 LS1 (Stock Bore and pistons). I know GM makes a few different head gaskets for the LS1.
They have these 2 different ones?
12498543 - 97-01 LS1 Engine Head Gaskets
12498544 - 02-04 LS1 & LS6 Engine Head Gaskets
Is there anything else I can use?
There are Felpro options as well??? But have have no clue as to the numbers.
I want the MAX compression I can get with these heads and this block. But I dont want to run an expensive *** Cometic gasket.
My main questions are what gaskets do I run? and what is their compressed thickness?
Thanks
Steve
Thanks
Steve
Mr. Gasket 0.042” Head Gaskets
Mr. Gasket makes head gaskets for ls1 stock bore .042 compressed thickness.
Ultra seal line part# 5713G for the left side, and 5714G for the right.
The cost $17.00 each retail and are not MLS construction
