X4 with stock 853 heads
Old 05-01-2005, 03:26 PM
sandking's Avatar
Default X4 with stock 853 heads
Someone in another post said that the older heads did not like the bigger cams, is that true? My heads are stock unmilled, unported, but will have new springs, seats, seals and retainers. I know they wont flow 300 cfm, but if the heads will not work well with these larger cams, I will need to port or replace. What are your opinions?? Thanks, Joey
Old 05-01-2005, 05:18 PM
sandking's Avatar
Anyone??
Old 05-01-2005, 07:30 PM
scottyballs's Avatar
i did not know there was a difrence I thought it was just the intake ??
Old 05-02-2005, 12:16 AM
sandking's Avatar
For cam only cars, does it matter what heads are better? Does one year have an advantage over another?
Old 05-02-2005, 01:34 AM
jrp
SN95 Director
jrp's Avatar
241 cast heads were Die Cast which is a process that smooths up the ports a bit compared to the Sand Cast procedure that was done on the 806 and 853 heads. Once ported any "advantage" the 241 cast had is moot
Old 05-02-2005, 01:43 AM
LS1TECH Sponsor
Magnus's Avatar
I have the old 84x heads and have gone 10.29@128 cam only.
My heads have never been off the car.
