when i turned the heat on the car started to bog and act funny. help!!
Old 05-12-2005, 09:12 PM
92 z28's Avatar
Default NOW THE CAR WONT STAY ON..when i turned the heat on the car started to bog
hey, i recently purchased a 99 ws6 m6 with 37kmiles. the car is extremely clean and you can tell good care was taken with it. the car has a centerforce clutch, 410s, borla catback and an aftermarket lid (it says ls1 in red on it). well i just recently started driving the car (it sat for the winter) and since i started driving it i havent turned the heat on. tonight i turned the heat on and immediatly after i did that the car started to react funny. the car starting bogging out while driving and during idleing the rpms would abnormaly fluctuate, as if the car was sruggling not to stall. i have no idea what is causing these problems but until tonight the car was running perfect! i did a search and i couldnt find anything even similar to my situation so i know this is a unique case. i really need to know whats going on, maybe a sensor is bad or something? this is really making me down since my new baby isnt acting right. any help or suggestions would be GREATLY appreciated. thanks!
Old 05-12-2005, 09:32 PM
DaddySS's Avatar
That's a strange one but two thoughts:
First, the heater controls are vacuum operated so if you have a leak it my be causing you to lose engine vacuum.
Second, look at your voltage, does it drop when you put the heat on? You would think that a short in motor bad enough to cause the voltage to drop would blow a fuse...but....check anyway.
Old 05-13-2005, 09:46 AM
92 z28's Avatar
the voltage is one of the first things i looked at and it looked strong and stable the whole time. the vacuume thing is a thought though.. how should i cueck this?
Old 05-13-2005, 01:51 PM
Moderator
jimmyblue's Avatar
Listen for any hissing sound under the dash that
is more than momentary, when you turn the heat
on.
Also some of the heater positions run the A/C
compressor as well (like defrost and the defrost /
heat combo for sure, maybe the hi/lo as well).
That puts more load on the engine. This should be
compensated for by the PCM but if, say, the A/C
compressor was taking more than a normal amount
of torque, maybe the compensation is a little short.
But I think that can learn?
Old 05-13-2005, 04:59 PM
2001CamaroGuy's Avatar
that would be my guess..........other than an electrical load, the heater does not cause a direct mechanical load on the engine (like AC)......
acting funny usually has to do with vacuum (or lack of it)
Old 05-13-2005, 07:11 PM
92 z28's Avatar
where and how do i look for vacuum leaks? i read you can spray carb cleaner on it but id rather not spray that around my clean engine.
Old 05-13-2005, 08:51 PM
1BADAIR's Avatar
The compressor runs if the defrost is on...
Old 05-14-2005, 02:18 AM
92 z28's Avatar
so tonight i take the car out to a car meeting and as soon as i pull into the parking lot the car dies. i try starting it up, it will fire up and 2 seconds later will shut off. i had to be flat beded home. i have no clue whats going on. where are the vacuum lines located so i can check those?
Old 05-14-2005, 02:41 AM
Z-286speed's Avatar
I would have to say you have more than a vacuum leak. You turn off your heater when restarting? Sounds like somthing eletrical.
Old 05-14-2005, 02:43 AM
92 z28's Avatar
to add some information i cleaned the ls1 engine bay like the sticky post in the appearance section says to do,,, spray down the engine with water is one of the steps. from what i have read this ok so i dont know if this could be an issue to consider? im soo confused at this point
Old 05-14-2005, 02:44 AM
92 z28's Avatar
if its electrical where do i start looking?
