another milling ?
another milling ?
How much should I mill stock LS6 heads (243) to get around 11.0:1 CR with stock MLS gaskets? Would there be any sort of clearance issues with a 224 sized cam? Is 11.0:1 "safe" for a stock bottom end with no plans of blowers or nitrous in the future? If not what would be a better target CR for this set up? Thanks for your input!
Originally Posted by Cal
I may be mistaken, but I thought stock 2002 MLS crushed head gasket thickness was .052 not .060
If using a .052" gasket though, .014-.016" milled off should get you 11.0 CR
Dan
sorry about confusion on the gaskets.. they are the 02+ style metal gaskets..
http://www.paceparts.com/index.asp?P...earch=12498544 for clarification and thanks again for your input!
Kevin
Kevin
If I were you, I would get a .040 or so gasket and do not mill any further. The more you mill, the more you loose in flow.
Reducing gasket size is a better way because:
1- You keep more chamber and are able to flow more.
2- You tighten you quench and have less detonation problems which is one of the criterias in running higher SCR motors.
