Brand New LS1 owner - t-stat question
Hey all. Last week, I bought a 1999 Trans Am Ram Air and absolutely love it! What a fast damn car!
Anyway, I have been searching the threads and have not determined what is the best temperature thermostat to buy for this machine. I am leaning towards a 180 but am not sure.
I intend to eventually buy a K&N filter, Crane Programmer and Flowmaster exhaust and that is probably all.
What thermostat should I get???
Thanks in advance.
The Josh
Thanks in advance.
The Josh
Thanks in advance.
The Josh
Thanks in advance.
The Josh
http://www.vincihighperformance.com/fbodyls1.html then click cooling. i use their 170* t-stat in both of my cars. i also use the vinci/crane handheld tuner with them as well. and skip the flowmaster as well. my suggestion is to go duals right off the bat. i have the bassani tru-dual on both cars as well. picked up .3 and 4 mph over a cutout. on the wife's car, i picked up 15 rwhp over the borla exhaust.
According to what many people here on the forums have said, the 180* thermo only opens a hair before the stock thermostat, despite the fact that it is said to open at 195*, making any difference in engine temperature negligible. If you have your mind set on changing it, you will need to go lower to a 160 or possibly 170. If you are going to go with the Crane programmer, you might be wise to lower the temps the computer kicks on the fans (the stock settings are pretty high). Someone correct me if the Crane can't do this, but this seems to be a common feature of the handhelds. You might search around the old posts here and look for the pros and cons of each mod before you do them, as they exist for the mods you listed.
Also, welcome to the ls1tech forums
yes the vinci/crane tuner does alter the fan settings. either stock (230*), 210*, or 190*. here's a tutorial about the vinci/crane tuner http://www.stealthram.com/vhptuner.htm
Thanks for all of the ideas. I read in the manual, as well as on this site, that the stock thermostat begins opening at 177-184 degrees. If that is indeed accurate, then really I can use the stock thermostat with the tuner and change the fan on temperature with no probelms, right?
Also, Why is there usch a wide variation in opinion about the thermostat temps anyway? I read that some people run a 160 and some people run 180 and some other run stock t-stats with lotsa mods on their rides.
On my last f-body (92 Z28 w/L98), I would have probably killed my engine without a lower temp t-stat and I didn't even have any mods on it!!!
Still trying to figure out this LS1 motor.
The Josh
The Josh
The Josh
The Josh
