408 w/ TEA 5.3's? Flow #'s inside
How would these heads flow for a 408? TEA 5.3's
LIFT Int Exh.
0.1000 69.5 52.2
0.2000 139.9 114.5
0.3000 200.7 159.9
0.4000 245.9 217.9
0.5000 284.7 246.7
0.5500 298.6 259.3
0.6000 307.6 265.9
LIFT Int Exh.
0.1000 69.5 52.2
0.2000 139.9 114.5
0.3000 200.7 159.9
0.4000 245.9 217.9
0.5000 284.7 246.7
0.5500 298.6 259.3
0.6000 307.6 265.9
I had heads that flow very similar to those. With a 90/90 1 7/8 lt's and everything else.... 238/242 xer 10.1/1 a4 c5 452 rwhp.
I switched to AFR/TEA stage III's.... 505 rwhp/473 rwt at 11.3/1
Originally Posted by Blue Falcon
Close to 30 or so, of that was from compression alone though, I'm already going to be at 11:1 with my TEA heads
I 2nd the compression ratio statement.
Those heads would work ok but the problem is if you set up an engine to use them with the samll chamber then decide you want to go to a Stage 3 truck head or a 225 AFR head then you will not have enough compression with the larger chambers they come with.
Also our 5.3 heads ussually flow about 15-30cfm less than our stage 3 heads. This is especially evident in the midlifts numbers.
