AFR's,Fast 90,NW 90TB,Poly mounts and Fast rails finally done
Well I finished the heads,intake,TB,fuel rails,poly motor mounts and braided fuel line. What a bitch of a job but it is done! I want to thank my buddy Mike and Gene of Gene's auto repair for all the hard work. These are my friends that put up with me for two long days. It would have went quicker but all three of us are perfectionists when it comes to our cars. I could not have done it without them so thanks once again guys. I could not even imagine doing motor mounts in the car what a BITCH even with the motor sitting down on the floor on it's kmember it was a pain to do. I will say that it is one of the best mods I have done so far to the car. The motor does not shake in the car it stays as still as can be with no exhaust banging the floor.
I also suggest if you do fuel rails to get the fitting that is shown in the pictures to attach to your factory fuel line. I just got home a few minutes ago from a long day finishing up the car but was too wound up to go to sleep so I wanted to post my results and share them. Dropping the motor to do heads is the best and would suggest doing it that way so there would be no problems with prep work for mounting your heads and getting a good torq and making sure your surface to the head and block is clean. Most of all that there is no coolant in the head bolt holes. I almost forgot when we did the head install we pulled the two brass plugs on the bottom of the block to drain most of the coolant still in the heads even though we drained the rest of the cooling system. It made clean up of the head bolt holes a breeze to do with very little coolant when the heads came off. I would say it was only a few ounces of coolant if I had to guess great call on that Gene. Well I have said enough enjoy the pictures. I forgot to mention the car feels great and the 90mm NW TB has great throttle response.
question.... hwat is the braded lines comign off the end of the fuel rails.. on my tnt wet kit and stock fuel raisl this is where my kit draws the fuel from.... loks like u dont have a n2o kit. so what are the lines coming off?
Beautiful pics man. Very nice install too. It must be nice to have access to a shop like that..you're lucky. Tell us more about that fitting for the stock incoming fuel line, where'd you get it, what's it called..etc.
I remember when my engine and engine bay were that clean and pretty. My engine bay looks like an old fightin' dog's head now...haahahaaaa
Thanks for all the compliments on my car guys.
The color of the paint on my valve covers is Ford red high heat engine paint.
The fuel line fitting I got from some place on the internet but I can't remember the name. I have the name of the link on my work computer I will post it up when I get to work Monday.
The size of the drain plug on the driver side is a huge allen head I will find out the size on that also.
No problem on the help. All I can say is "you got some big ones" to do that job. The car turned out great... Now get it tuned and lets run it! That 90mm sure was sucking in the air like a vaccum-cleaner!!!!!!!
My car is next!
My car is next!
Originally Posted by Caveman
Wow your car looks great Lou. The install looks like a very clean job, good work. Now hopefuly the car will actually run some decent times NA but I doubt it.
Keith I need to get with you and see what your injector flow table looks like and compare it to mine. Shoot me your file over in an email to me if you could here is my email address Louiespaccio@cfl.rr.com. I guess we will see how stong a full built Burges tranny really is so far so good. Then again you can only do so much to a 4L60E to begin with.
Here is the link to where I bought that fuel line adapter at.
http://purechoicemotorsports.com/ part #5800 but you only need one so specify that when you order.
Here is the size for the block drain plugs that I talking about.
17MM Allen front left behind alternator.
T50 torx rear drain over starter.
Originally Posted by HavATampa
Awesome tip on removing the 2 block plugs before removing the heads. I no water to clean up from the head bolt holes or the cylinders. It's worth the extra effort to remove the plugs. Thanks again for the info 02 Pewter LS1!!
