? About Cometic MLS Gaskets
Old 06-13-2005, 09:02 PM
BoneSS's Avatar
Default ? About Cometic MLS Gaskets
Do I need to use some kind of sealant or anything between them and the block and/or heads?
Old 06-13-2005, 09:09 PM
tonyb's Avatar
No,install them dry and make sure things are very clean and grease free.
Anthony
Old 06-14-2005, 01:17 AM
LS1TECH Sponsor
Steve - Race Eng's Avatar
Default Cometic
Anthony is correct. I highly recommend you retorque after first heat up cool down cycle if using not stock fasteners.
Steve
Anthony
__________________
Steve Demirjian
Race Engine Development
Oceanside, Ca.
760-630-0450
web: www.raceenginedevelopment.com/
e-mail: race-engine-development@***.net
Old 06-14-2005, 01:45 AM
strokedls1's Avatar
I spray both sides of the gasket with permatex copper spray and torque to 80 lb-ft with arp studs.
Old 06-14-2005, 06:33 AM
BoneSS's Avatar
I've seen several people you the copper spray on here--it that overall recommended?
Old 06-14-2005, 07:37 AM
02 Pewter LS1's Avatar
Installed mine dry and used ARP bolts and torqued them to spec with no problems. I agree make sure you have a good clean surface before you start. I wanted to use the copper spray but Tony at AFR told me to put them on dry so I did.
Old 06-14-2005, 07:57 AM
BoneSS's Avatar
Thanks again--I will stick with what Tony said then.
Old 06-14-2005, 10:35 AM
ArcticZ28's Avatar
I used a small film of copper gasket spray as well. No problems whatsoever here. I've heard of more problems without the copper gasket than with.
Old 06-14-2005, 10:39 AM
lsevenl's Avatar
installed dry, torqued down, no problems at all.
Old 06-14-2005, 05:56 PM
Viper's Avatar
LS1Tech 20 Year Member
My engine builder went dry, but question:
How many of you guys with ARP's had to go back and retorque after the first heat cycle?
Thanks. Firing up the new motor Saturday.
Old 06-14-2005, 05:58 PM
ArcticZ28's Avatar
I haven't gone back and re-torqued.
Old 06-14-2005, 06:00 PM
pdd
pdd's Avatar
me too so far
Old 06-14-2005, 11:38 PM
ScreaminDemon's Avatar
I fired up my Darton wet sleeved 427 yesterday and have a water leak at the bottom of the head at #3 cylinder. Used ARP studs torqued to 65/fps as told by Cartek and used the Cometic gaskets. Darton has said a leak can be common and that alot of people use the copper gasket spray. My leak has stopped so far today but I think I will torque them down alittle more when I readjust the valves. I'll use the spray if i still have the leak later. By the way, can this Cometic gaskets be reused/retorqued?
David
Old 06-14-2005, 11:53 PM
strokedls1's Avatar
Cometics can be reused. Follow their instructions if you do so.
Old 06-15-2005, 12:21 AM
ArcticZ28's Avatar
There's no reason not to use the copper gasket spray.
Old 06-15-2005, 06:53 AM
BoneSS's Avatar
Where can you pick the spray up at?
Old 06-15-2005, 07:47 AM
LS1 BU's Avatar
I have resued mine three times. I have never used and sealant.
Old 06-15-2005, 10:10 AM
ArcticZ28's Avatar
Any parts store should have it. It's made by Permatex. I believe it's in a copper colored can and titled "copper spray gasket" or something of the likes. You can't miss it.
Old 06-15-2005, 08:45 PM
BoneSS's Avatar
Cool==thanks!
