Couple questions on my motor build
Ok cars a stock 98 Camaro LS1 Automatic Car 62 thousand miles. Heres what I have for the car.AFR 205 Heads complete,TSP Magic Stick Cam,LS6 intake,LS6 PCV system,02 Camaro SS Vavle Covers,Electric polished Water Pump stant 160 Stat,ASP Under drive crank and over drive alt pulleys,LPE Power Steering pulley,Hooker Long tubes,3 inch QTP Electric Cut-outs,Speed inc high flow fuel rails,racetronix 42lb injectors,NOS Wet Kit,NOS Heater,Air Fuel,trans temp and bottle pressure gauges,fuel pressure gauge 0-100,ARP Rod Bolts,ARP Head Studs,4400 vig converter,B&M Deep Trans Pan BMR Sub Frame Connectors,BMR Lower Control arms and relocation braks,3.73 gears,ported maf and ported tb,a few other things.My question was the motor is out but im wondering since im changing the rod bolts should i add a set of arp main studs and what else can i do to add some peace of mind to the car Thanks sorry for the long post
Originally Posted by ArcticZ28
forged bottom end
Stock pistons won't like heads, cam and nitrous very much.
Also, are you sure 4400 isn't too high of a stall to run with on the bottle?
Be nice to that transmission, you may end up shopping for a rebuilt one or a turbo 400 swap before too long.
That is my eventual plan. Already have bolt ons and MS3, still need suspension, little things, forged internals, heads and the nitrous. Man, I have a long way to go.
ok i called texas speed today and spoke with brain there.hes getting me some prices what am i looking at to spend for a stock length forged rod and what pistons should i look at getting and whats a ball park on price ill have to by one first then save up for the other thanks also after i do the rods and pistons is there anything else i should do and how much power will that hold ps already looking at a turbo 400 trans and prob wont use spray until on the dyno only for a nice tune
