Head and cam swap and mileage
Old 06-17-2005, 07:03 AM
Stealthrider's Avatar
Default Head and cam swap and mileage
I have a 2002 M6 Firehawk with 14500 miles. I want to do a head and cam swap but I am worried that I may have too many miles to do it. Can I do it without having to rebuild the engine or upgrade any other parts of the engine?
Old 06-17-2005, 07:08 AM
equandt's Avatar
You'll be fine. I did my swap at 29,000. Absolutely no problems. There are a lot of guys modding 90,000+ mile engines on here.
14,500 is barely broke in good.
Old 06-17-2005, 07:14 AM
PREDATOR-Z's Avatar
Should be easier, you won't even have to change chain or oil pump. Piece of cake.
Old 06-17-2005, 07:44 AM
Tally TransAm's Avatar
i did my first cam swap at 60k, heads at 75k, and next cam at 80k
i think youll be fine
Old 06-17-2005, 09:01 AM
GuitsBoy's Avatar
My cam went in last weekend at 77K. The old cam coming out still looked new.
Old 06-17-2005, 10:34 AM
hpjunky98's Avatar
dude there is no reason that should be an issue. 14500? if you had ten times that, then we would say it would be a problem!
Old 06-17-2005, 11:10 AM
SS3520's Avatar
I have 45,000 on my heads and cam and still running strong.
Old 06-17-2005, 11:13 AM
GuitsBoy's Avatar
There are many 145K + ls1s , both modded and unmodded, that are running quite strong. There was a turbo 98 formula a sponsor had with 130K pushing ~800 RWHP or so on the stock bottom end for hundreds of pulls before the stock bottom end let go.
Old 06-17-2005, 01:05 PM
00Z28 Camaro's Avatar
is camming at 87K iffy ?
Old 06-17-2005, 01:23 PM
GuitsBoy's Avatar
No, I just did it at 77K.
Old 06-17-2005, 01:42 PM
PREDATOR-Z's Avatar
Guys the miles on a motor are irrelative.
This is my recomendation upon wanting internal modding:
1- Do a compression test
2- Do a leakdown test
Once you have the results on these two, you make the decision on how to proceed.
Old 06-17-2005, 01:49 PM
GuitsBoy's Avatar
This man knows a lot, and this is probably the best advice youll even hear on the subject.
I will also add, that if youve owned you car the entire time, you kow exactly what it's been through. If youve put it through hell and back, dont expect it to live forever with new mods. If youve always taken care of it and kept on top of the maintenance, mod on with confidence. Id rather drive a car with many well cared for miles, than a car with lower, but hard and neglect ridden miles.
Old 06-17-2005, 04:35 PM
Blue Falcon's Avatar
I did a Heads/cam swap at 113k miles
Old 06-17-2005, 05:26 PM
DaddySS's Avatar
You would think they meant 145000, I can't imagine anyone being concerned at 14500!
