Think i'm finally going to a TTP 395
well i think i might have TTP build me a 395 stroker with Lunati forged parts and reuse my A/S stage 2.5 5.3 liter heads. I'll be giving them a call tommorow and get all the last little details before i go ahead. Whatda think
Super Hulk Smash
4.125" stroke cranks had oiling problems. I don't know if that's been fixed, or if that was a particular engine builder that the problem was with. But, I'd look into that because that's an out of square motor with its 3.905 bore and 4.125 stroke.
And yes, the 408 would be better, overall, but for what you already have parts-wise, the 395 might work well and make you some nice power, especially with TTP building it. Although, ditch those heads and just get the TTP Stage 4R head/cam package since that'll make as much power as the 395 with your heads and cost less.
I'm still not sure if i should go 408 or 395. I would like not to spend more money on heads again plus i want to stay with an non steel block. would my headers be good for a 408, Kooks 1 3/4 stepped to 1 7/8. I would like to build a nice motor but i do not want to break the bank
Going Alum sleeved block, I would spend the money on those things,
1- The block (IMO Steve Damijian is the best)
http://www.raceenginedevelopment.com/
2- the lightest rods
3- The best heads.
3- The best heads.
Super Hulk Smash
Like I said, just go with the TTP 4R H/C package. 500+rwhp in a 346 for 7k with FAST LSX90 since you already have the Kooks Stepped Headers. If you want more, forge the engine and spray a 200 shot on it. The 395 isn't going to do much better HP wise, but will make more torque, and a 408 will make more everywhere while being more streetable, but the engine itself will cost you 10-11k+FAST 90+Fuel System+labor. All-bore aluminum block is going to cost you as much or more and make the same amount of power.
Brandon
We have a 395ci package that is almost daily driven by a customer. Absolutely no oil issues, does not burn one drop. There are a few things that we do to our 395 / 4.125 stroke packages that has avoided the infamous oil issue.
