Who is using TSP Torquer 2 cam???
Old 06-30-2005, 07:15 PM
SideStep's Avatar
Default Who is using TSP Torquer 2 cam???
I am interested in performance, idle, part throttle low-rpm response... blah blah blah...
Specs 232/234 .595/598 lsa113+1 ???
Old 07-01-2005, 05:15 PM
DWillTA's Avatar
I am also interested in a similar spec'ed Comp Cam. PN 54-446-11 Specs 232/234 595/598 LSA 112 ICL 110 (I think)
I think it is comparable to a F14 but have yet to see any cam card specs to validate that speculation. Any info would be great. Thanks
Dave
Old 07-02-2005, 08:01 AM
SideStep's Avatar
Old 07-02-2005, 08:45 AM
HavATampa's Avatar
You guys do know there is a search feature on this board....right? If you look down about 12 post from this one on the first page there is a poll with about 18 replies comparing the Torquer 2 to the F13. Plus in the Dyno Forum you'll find tons of info and specs on this cam.
Old 07-02-2005, 08:57 AM
SideStep's Avatar
Did a search before only found 2 results that were the new Torquer 2 and had dyno-graphs... Everyone is still using the old one, very few on the new specs with dynos to prove it... All I find there is conjecture and discussion about what it might be like. I want data and experiences from those that have it installed. I called Jason at TSP and was told there are simply not that many of them out there yet...
Old 07-02-2005, 11:33 AM
co.6z28's Avatar
i just ordered one, so i can post my results when i get her in. i know it is ground on a 113 and 112.
Old 07-02-2005, 12:05 PM
SideStep's Avatar
What did you get, 113???
Old 07-02-2005, 01:21 PM
co.6z28's Avatar
nope 112
Old 07-02-2005, 01:41 PM
LSxGuy widda 9sec Mustang
-Joseph-'s Avatar
I installed one of the new ones about 2-3 weeks ago although I didn't get a chance to drive it (I hardly even road test customers cars). All I've done since then has been MS3's, for some reason... The owner has remarked that he was surprised by how drivable it was. I think Jason posted that particular dyno graph in the dyno forum also. I don't keep track of what cams/quantity go out, but I'm sure there are many more results out there that'll show up. The search may not be fully working yet, It was acting up on me the last few days also.
Old 07-11-2005, 07:43 AM
KB99WS6's Avatar
Why was the original revised? The original is a 233/233 .595/.595 correct?? What were the reasons they changed it to a 232/234 .595/.598??
Old 07-11-2005, 11:34 AM
co.6z28's Avatar
to make more power
Old 07-11-2005, 12:35 PM
KB99WS6's Avatar
but there wasn't any problems with the first one, right? I'd like to see a cam swap of the first and revised and side by side dyno comparisons. Probably not much of a difference though.
Old 07-11-2005, 04:04 PM
Kennedy98z28's Avatar
I have the original 233/233 .595/.595 in my car. It helped my car out alot.
Old 07-11-2005, 05:00 PM
-Joseph-'s Avatar
V1 was Lunati lobes and V2 is ground by Comp. Although the specs are similiar the V2 seems to make a little more power down low, about the same peak power.
